Can I Add A 20 Amp Circuit To This Panel Box? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-12-2009, 07:50 AM   #16
Originally Posted by MI-Roger View Post
I am surprised this is allowed.
It seems that a tub would be considered a permanent fixture and would need to be hard-wired, or pluged into an outlet adjacent to the pump, which would make the outlet inaccessible for ease of reset. Either of these installation methods would require a GFCI breaker.
As picky as code officials get about everything else, I still can't imagine that a heavy duty cord, protruding from a jacuzzi tub, could be allowed to drape across the floor/wall to plug into a GFCI outlet. Sections of the code specifically prohibit locating other types of disconnects, or reset means, or circuit protection devices in locations which are inaccessible or require tools to access. Unbolting a panel from a tub surround to unplug a motor cord from a receptacle is not the same as opening a hinged cupboard door to unplug the garbage disposal.
I suppose the inaccessible convenience plug next to the jacuzzi motor could be daisy-chained from another GFCI device in the same bath. But what is the power draw of the pump (and blower) motor(s)?
Not to hijack this thread, but I can easily imagine a situation where every code requirement pertaining to indoor swimming pools would be applied to whirlpool tubs.
My tub has removeable sides that allow easy access to the GFCI, nothing to unbolt - velcro
The tub comes with a plug, MFG instructions state to install a GFCI outlet
Modification would void the warranty
There isn't any cord running across any floor or even visible
The outlet for the pump can be a normal outlet that is off the load side of a GFCI outlet in a more accessible location
My pump pulls 7a, not sure on others - I would never pull power for something like this from the bathroom circuit
Indoor swimming pools can have the pump plugged into a GFCI outlet
Old 11-12-2009, 09:00 AM   #17
300zx's Avatar
Post
Dave is right as usual Hot tubs have accesbility on them i still put them in the master closet
300zx is offline   Reply With Quote
Old 11-12-2009, 09:14 AM   #18
Ditto on ours.
Salem747 is offline   Reply With Quote
Old 11-12-2009, 10:25 AM   #19
Licensed Engineer
Rewards Points: 171
Thanks for the info.........
Velcro definitely provides easy access. I was picturing installations where a factory assembled whirlpool tub is dropped into a field constructed raised platform - often with tile on the riser.
MI-Roger is offline   Reply With Quote
Old 11-12-2009, 10:27 AM   #20
Ours actually has access to the plug through the master closet and in the crawlspace between the pony all and the end of the cathedral ceiling through a little doorway.
Old 11-12-2009, 12:04 PM   #21
Regarding the Jacuzzi tub...it is plugged into a GFCI outlet located next to the pump. It is the only outlet on that circuit. The outlet and pump is easily accessible from a 14"x14" metal access door installed on an adjoining wall (my bedroom).
Regarding the panel box...I will pull all of the manufacturer and model information later today and post it. I could really use all of your input. Thanks.
imlos is offline   Reply With Quote
Old 11-13-2009, 11:53 AM   #22
Okay, the inside of the panel box is not real easy to read, but this is what I think I have:
Crouse Hinds JA1120Y Model H
Old 11-13-2009, 12:07 PM   #23
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
If I am understanding that model number correctly, no, you cannot add a tandem, split, or any other type of less than full size breaker.
In fact, your panel is illegal as it is. You are only allowed 20 circuits in that panel and you have 22.
You also need to label the 100 amp breaker as "service disconnect" "main breaker"
100 -> 200 amp panel upgrade questions philipjcaputo Electrical 1 10-30-2009 04:35 AM
120 v circuit from 230 volt panel mills372 Electrical 3 09-07-2009 12:13 PM
Old Electric Panel/ Circuit Breaker Box dankreboot Electrical 3 12-16-2008 01:52 PM
Sub Panel SoxFan Electrical 2 12-02-2008 11:16 AM
Replace a service panel circuit breaker knockout? michigan_homeowner_2008 Electrical 6 05-22-2008 05:01 PM
