Can Grounding Plates Go In The Same Hole - Electrical - DIY Chatroom Home Improvement Forum
Old 06-13-2012, 02:09 PM   #1
can grounding plates go in the same hole
can grounding plates go in the same hole as under ground electrical.. i am down 36 inches for the pipe just wondering if i can lay the ground plates at 2 foot level and cover over .. i am in ontario canada
chessy is offline   Reply With Quote
Old 06-13-2012, 03:49 PM   #2
Rewards Points: 130
I am sure you can as long as its deep enough. Hang on as we do have some guys here from Canada. Marc where are you?
cable line grounding amakarevic Electrical 56 05-15-2012 09:22 PM
Sump hole and water drain questions Ncasalejr Plumbing 1 06-21-2011 09:57 AM
Deadbolt too large for deadbolt hole in frame? wysiwyg6000 General DIY Discussions 2 01-01-2010 10:06 AM
Grounding Method Steelhead Electrical 6 02-05-2009 11:06 AM
A Hole to Nowhere fw2007 Electrical 12 03-24-2008 10:28 AM
