Can GFI Work With No Ground Wire? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-30-2009, 11:16 AM   #1
Rewards Points: 682
Can GFI work with no ground wire?
We have some old electrical systems done before code required a 3rd ground wire. Is it possible to make a gfi outlet work on one of these old lines, or does it require a ground wire?
darsunt is offline   Reply With Quote
Old 04-30-2009, 11:21 AM   #2
Licensed electrician
Rewards Points: 1,622
GFI's will work without a ground wire. A three light plug-in tester will not trip a GFI without a ground.
Also use the 'no ground' stickers in the box on the protected devices.
Old 04-30-2009, 12:20 PM   #3
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
GFCI's installed in a box without a ground will still work as designed for people protection but as pointed out the test button on a three prong GFCI Test will NOT work because that type tester connects a 5mA bleed resistor between Line and Ground.
GFCI's are designed so that Ground is not required for the built in Self-Test button ON the GFCI.
This is done by connecting the Test bleed resistor back to the input side of the CT.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 04-30-2009, 04:07 PM   #4
Not only possible but preferable.
You can legally install 3 prong receps on a 3 wire system if the citcuit is GFCI protected.
The GFCI simply measures current incoming on the hot wire and compares it to the returning current on the neutral wire.
If there is more current going out than coming back, it assumes it's going to ground and opens the circuit.
220/221 is offline   Reply With Quote
Installing light fixture.....ground wire? yummy mummy Electrical 15 02-19-2009 11:33 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
smoke alarm - ground wire Potomac101 Electrical 7 02-06-2008 07:25 AM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 06:30 PM
Ground Wire Problem ScubaRaven Electrical 11 06-08-2006 02:32 PM
