Can GFCI Circuit Breaker Handle Combined 240V And 120V Circuits? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-12-2013, 10:28 AM   #1
Question
Can GFCI circuit breaker handle combined 240V and 120V circuits?
I want to run a 240V 40A circuit (red/black/white/bare) from my main box to my attached garage. I would also like a 120V 20A circuit out there as well. It seems like I can install a sub-panel with a 20A breaker in the garage and supply it from one leg of the 240V. Being in a garage I will need GFCI protection. If the main box uses a 240V 40A GFCI circuit breaker, will the 120V circuit "confuse" the GFCI? That is, the 120V will be returning current on the white/neutral wire, while the 240V will be returning current, alternately on the hot (red/black) wires. The GFCI has connections for all three, so I could imagine it can metering the total out-current and comparing it to the total in-current. Can it?
muncheroo is offline   Reply With Quote
Old 04-12-2013, 10:33 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 254
It would work, but I would not go through that expense.
Use a standard breaker and use gfci receptacles where they are needed.
jbfan is online now   Reply With Quote
The Following User Says Thank You to jbfan For This Useful Post:
micromind (04-13-2013)
Old 04-12-2013, 10:45 AM   #3
I am all for avoiding unnecessary expense and a GFCI circuit breaker is indeed expensive! However, while 120V GFCIs outlets are cheap and available, I haven't had much luck finding GFCI's for 240V. That strikes me as odd, since I would expect the need to be pretty common. Are they out there?
Old 04-12-2013, 11:28 AM   #4
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Only 120v recepts need GFI protection.
The Following 2 Users Say Thank You to k_buz For This Useful Post:
micromind (04-13-2013), stickboy1375 (04-12-2013)
Old 04-13-2013, 12:42 AM   #5
" Euro " electrician
frenchelectrican's Avatar
I know the state side the garage you can use the GFCI on 120 volt 15 or 20 amp circuit but for 240 volt useage almost never used unless specfic equiement call for that. so run the 240 volt circuit in convental manner.
Merci,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
Old 04-13-2013, 10:30 AM   #6
Rewards Points: 1,192
Spas,pools and hot tubs??? 240 volts.
bobelectric is offline   Reply With Quote
Old 04-13-2013, 10:37 AM   #7
k_buz's Avatar
That would be required in a different section of the NEC and would not fall under the garage wiring code.
The Following User Says Thank You to k_buz For This Useful Post:
Old 04-13-2013, 10:38 AM   #8
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Are we talking about Spas, pools and hot tubs?
Old 04-13-2013, 10:42 AM   #9
Only 120 volt receptacles are required to be gfi'ed.
The Following User Says Thank You to bobelectric For This Useful Post:
Old 04-13-2013, 01:02 PM   #10
Idiot Emeritus
Rewards Points: 1,492
I agree with the others, just run a normal 120/240 feeder to the garage sub-panel and use 120 volt GFI receptacles.
120/240 GFI breakers up to 50 amps are available, but they're expensive.
micromind is offline   Reply With Quote
Tags
120v , 240v , gfci
Need advice on installing 240v and 120v circuits for dryer/washer brettnbham Electrical 4 03-25-2012 09:30 AM
Power 120V Pump from a 240V circuit RoberTX Electrical 26 07-06-2011 12:43 AM
switch from 120v to 240v new breaker popwarfour Electrical 24 04-28-2011 09:17 PM
Pulling 120V outlet from a 240V circuit? npage148 Electrical 12 11-08-2009 12:29 PM
120v for shed from 240v HotTub circuit? MrMark Electrical 6 04-06-2009 01:43 AM
