#1 |
can a fridge ever exceed 15A
my fridge is currently on a 20A dedicated circuit. i am thinking that 20A for a fridge is too much as i recall that a 15A is enough. i am doing some rewiring and want to go switch it to a 15A circuit with a AWG14 cable. just making sure that's OK.
#2 |
Resi EC
I'm just a little curious, why fix it if it's working?
All newly constructed homes I do have their refrigerators on 20a circuits |
#3 | |
Lic Electrical Inspector
can a fridge ever exceed 15AQuote:
All responses based on the 2011 NEC. If you live in New Jersey click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . All other states click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Please check with local, county and state officials as laws may vary. Sizing motors To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Online motor calculator To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Online calculators To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . |
| The Following User Says Thank You to electures For This Useful Post: | amakarevic (08-26-2012) |
#4 |
E2 Electrician
Unless a subzero is being installed, I generally just install a 15 amp circuit, sub zero is one manufacture that requires a 20 amp circuit... even though it is not required load wise.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| The Following User Says Thank You to stickboy1375 For This Useful Post: | amakarevic (08-26-2012) |
#5 | |
i am a minimalist and hate stuff visible if they can be hidden. |
#6 | |
Resi EC
| The Following User Says Thank You to Gac66610 For This Useful Post: | amakarevic (08-26-2012) |
#7 |
can a fridge ever exceed 15A |
#8 |
i would still run 12 awg cable. cost difference is minimal, voltage drop is reduced, and you have the choice to make 15A or 20A
#9 |
Resi EC
#10 |
E2 Electrician
I wouldn't, most fridges draw 6 amps... total waste of money. unless of course you have the #12 just laying around...
#11 |
mine draws 5.5.
maybe im the one with the clinical obsession. probably not borderline in my case. after all, im the one with the 8 ground rod system with #4 awg wire |
#12 |
E2 Electrician
I use # 4 also, but only because we only stock one wire size... 8 ground rods? total waste.. it serves no purpose.
| Display Modes | |
| Cabinet, Fridge, & Pantry fitment | mystic_cobra | Carpentry | 8 | 01-17-2012 01:36 AM |
| problems with fridge | clashley | General Discussion | 9 | 10-08-2011 07:54 PM |
| Fridge Diagnosed as "Unrepairable" | Old Lady | Appliances | 9 | 06-28-2011 07:08 AM |
| Help My Admiral Refrigerator is leaking water | Cuwillis | Appliances | 9 | 03-22-2011 09:40 PM |
| Water buildup in Fridge | mibson | Appliances | 13 | 01-06-2011 12:28 AM |
