Old 12-13-2008, 04:13 AM   #16
Electrical Contractor
kbsparky's Avatar
can this be fixed?
Originally Posted by KE2KB View Post
Isn't that the splice kit that was discussed in another thread a couple of months back?
It consists of heat-shrinkable tubing if my memory serves me.
If that is what you are referring to, it cannot be used in this situation. It is intended for underground splices, where chance of fire is minimal to none.
Nope. I was referring to a plug-in connector, commonly used in modular homes for interconnection of the sections made by Raychem/Tyco:
You are allowed to use this type of connector without a junction box for splices, repairs, etc. Perfect for this type of application.
Old 12-13-2008, 08:41 AM   #17
can this be fixed?
That splice thing looks like it could be used for zip cord, not NM cable.
I think code still says all splices need to be inside a J-box. Even if those little splice gizmos were allowed, I wouldn't use them.
Someone who knows the code better than I do will answer this for you.
KE2KB is offline   Reply With Quote
Old 12-13-2008, 09:01 AM   #18
My License Ain't 4 Sale..
can this be fixed?
These are legal, but not very sturdy, in my opinion. I have done alot of service in mobile homes, and the main failure points I have encountered were/are these types of connectors that join the parts together, and the enclosed feed-thru switch and receptacle design.
Ideally, the OP would change the cable. Probably not likely. The best splicing solution, at least in my opinion, is two junction boxes. But in all reality, if that black wire is not nicked to the copper, and the conductors are not otherwise damaged, a couple wraps of tape would probably be best. White tap if you like. Like I just read, K.I.S.S.
Old 12-13-2008, 05:37 PM   #19
can this be fixed?
The splice thing is stupid. Two plastic jb's/blanks would cost 3 bucks and take ten minutes.
A butt splice is a bad idea also. At this point, the wire is not damaged...only the insulation. If you cut the wire and butt splice it you create a worse condition.
The handyman who did this needs a $10 non contact tester for Christmas.
220/221 is offline   Reply With Quote
Dimpled nails in cladding - should this be fixed? dragonness Building & Construction 13 07-10-2008 05:25 PM
Anyone ever fixed a Rainbow vacuum? billmac Appliances 3 06-30-2008 11:32 AM
Leaking fixed skylight mt232 Building & Construction 5 11-23-2007 11:12 PM
TXV or fixed cjett HVAC 1 09-29-2007 04:38 PM
Wet Basement being fixed (pics) harleysilo Remodeling 2 01-23-2007 09:09 AM
