Can Electrical Wire Go On The I-Beam - Electrical - DIY Chatroom Home Improvement Forum
Old 08-12-2011, 07:46 PM   #1
Can Electrical Wire go on the I-Beam
I've been pouring over some books and the web looking for a solid answer to this. Can I run electrical wire over the I-Beam in my basement?
I need to run a wire and without going on the I-Beam I'd need to run it against the entire side of the basement, then halfway across the front of the house and then cut back to the center at the stairs of the basement to keep the wire running along the boards and not hopping over them. If I can secure it on the I-Beam I can save a bunch of extra wire and stapling.
thebrandnewguy is offline   Reply With Quote
Old 08-12-2011, 08:08 PM   #2
Missouri Bound's Avatar
Absolutely. But you must secure it as if it was along any other building material.
Old 08-12-2011, 08:30 PM   #3
what do i use to secure wire to the steel beam?
Old 08-12-2011, 08:45 PM   #4
Johnboy555's Avatar
Codes are different all over the place... The best idea would be to call your local home inspector and ask. Not knowing where you're from kinda keeps us blind in that area.
By "over" do you mean on top?, or within the recess of the side of the "I" beam?
I don't see any problem running it in the recess. As long as it's held in place by the finished surface.
Johnboy555 is offline   Reply With Quote
Old 08-12-2011, 08:59 PM   #5
right now i have an old wire that is running along the beam stapled to the cross wood beams. I want to run this new wire better. I obviously can't use insulated staples to put it on the metal beam. So, what do I use to secure it within the recess?
Old 08-12-2011, 09:01 PM   #6
Johnboy555's Avatar
Why not use some duct tape to hold it inside the recess? Once the beam is covered it's not going anywhere...
Old 08-12-2011, 09:22 PM   #7
Rewards Points: 558
I would run a plastic conduit along the inside of the beam fasten it with perforated strapping like this and feed your wire through. Use a ram set to shoot nails into the beam to hold the strapping in place.
you can get this stuff at any big box store and also rent the ram set gun.
epson is offline   Reply With Quote
Old 08-12-2011, 09:29 PM   #8
Licensed electrician
Rewards Points: 1,020
I would avoid the duct tape that was suggested. It would allow the cable to fall off after the tape got some age. It also needs to be at least an 1 1/4" behind the finished surface, unless fished. /the finished material cannot hold it in place.
A home inspector would not be a person to call. If anyone you need someone from your building officials office that deal with codes.
I have used short blocks of wood jammed in between the flanges and then staple the cable to the blocking.
Leah Frances (08-12-2011)
Old 08-12-2011, 11:16 PM   #9
Johnboy555's Avatar
I meant to say "building inspector". I wouldn't call a "house inspector" to OK anything... unless I REALLY knew him!! Half of these "house inspectors haven't a clue how things should really be done. They take a couple day course and they're "certified" !!
I had assumed that the beam would have been framed with 2 by's...
Adding ground in old home ChaosTheory Electrical 6 06-16-2010 05:02 PM
Crawl Space Beam and Joist Support Questions Fire4Effect Building & Construction 5 06-28-2009 02:07 PM
feeding electrical wire david_s Electrical 6 04-11-2009 06:32 PM
Cap electrical wire? oscarMadison Electrical 5 03-01-2009 10:26 PM
Standard gauge for household electrical wire tripower Electrical 2 09-22-2008 12:42 AM
