Can This Be Done? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-27-2011, 01:03 PM   #16
Licensed electrician
Rewards Points: 1,772
Under the 2008 or later all receptacles in a garage require GFI protection, including the garage door opener receptacle. The GFI must be readily accessible so ceiling mounted is out.
Old 04-27-2011, 01:07 PM   #17
Lost..
Rewards Points: 336
The rolling door is a hand operated door.
J S Machine is offline   Reply With Quote
Old 04-28-2011, 08:55 AM   #18
Just to stray off a bit, What software did you use to make your diagrams?
I want to document my bathroom rewiring and those diagrams would be perfect.
pgartner is offline   Reply With Quote
Old 04-28-2011, 08:58 AM   #19
Lost..
Rewards Points: 336
Microsoft paint. Simple, but effective I guess
Old 04-28-2011, 10:08 AM   #20
mem
Rewards Points: 156
Originally Posted by J S Machine View Post
I have a total of five plugs. Do they all need to be GFCI?
Run the power to the first GFCI receptacle's line terminals and connect the rest of the regular receptacles to the first one's load terminals and the whole chain will be GFCI protected.
mem is offline   Reply With Quote
Old 05-07-2011, 09:17 AM   #21
Lost..
Rewards Points: 336
Picked up two GFCI receptacles last night.
Another thing I have been curious about is if the ditch must be a certain distance away from the house. Is there any rule in the code that states such?
I'd like to start digging my ditch for the service line, and I don't want to have to go back and redig because it is too close to the house.
