#1 |
Lost..
Can this be done?
I'm going to get my shop wired soon and I'm trying to figure out exactly how everything will be done. I will have a panel with breakers controlling a few circuits. On one particular circuit, I have something I am not sure about.
1.) I have the panel. 2.) I have a single pole switch 3.) I have a light fixture overhead 4. ) I have one lonesome receptacle To avoid having to run the receptacle on it's own breaker and a dedicated circuit, I would like to have it tied in with the light circuit. Problem is, I can't figure out how to do it. I know this would be very easy to do if the source was coming from the receptacle side, but it is coming from the switch side. I drew up this diagram to help explain what I am talking about- ![]() I know I could simply run wiring all the way to the receptacle, and then back to the switch and light, but I'm trying to avoid wasting a bunch of wire if possible. The receptacle is way over on the end of the wall, so to do this would require about three times the wire I'll have to use if the way I'm thinking is possible. I'll have it done that way if that is the only option, but this is my idea: Run wire from panel to switch. Branch off from the switch to the receptacle, as well as branch off from the switch to the light. The switch controls the light and the receptacle or the receptacle can remain hot at all times..doesn't really matter as long as the switch controls the light. Is this possible or am I just wishful thinking? |
#2 |
I=E/R
Can this be done?
Bring the cable into the switch box and connect the three whites together, the grounds together, and connect the black to the source black along with a pigtail to the switch.
#3 |
Licensed electrician
Can this be done?
You could do the receptacle at the end of the run and it would be switch controlled. You could run 3 wire + ground cable from the switch to the light and then two wire to the receptacle and the receptacle would be hot all the time.
Answers based on the National Electrical Code. Local amendments may apply. Check with your local building officials. |
#4 | |
Lost..
Can this be done?Quote:
Is it possible to do that? |
#5 |
Can this be done?
If you want half your receptacle switched with the light and the other half hot all the time could you not just run a 3 wire plus ground from the switch to the receptacle?
#6 |
Lost..
Can this be done? |
#7 |
I=E/R
Can this be done?
A+
#8 |
Lost..
Can this be done? |
#9 |
Can this be done?
In the last diagram the receptacle would be hot all the time. It is commonly done.
#10 |
I=E/R
Can this be done?
I assume this is #12 so you will need a 22 cu in box and all the wiring has to be in #12 if it is on a 20 amp breaker. The receptacle will be 100% hot. Code allows lights and receptacle on the same circuit, but the receptacle will have be GFCI.
#11 | |
Lost..
I really didn't want to have to run a dedicated circuit to it, so this is good. |
#12 |
I=E/R
Can this be done?
You could put a double gang box in for a switch and a receptacle and then run the wire across the garage.
#13 | |
Lost..
Why do I need a GFCI receptacle there? Doesn't that require 12/3 wire? |
#14 |
I=E/R
Can this be done? |
#15 |
Lost..
Can this be done?
I have a total of five plugs. Do they all need to be GFCI?
| Display Modes | |
