Old 02-14-2012, 05:14 PM   #1
Can coaxial cable outlet be in same box as an outlet?
Can you have a coax cable outlet in a 2-gang box with a duplex electrical outlet?
Basement is unfinished with block walls. Planning on having conduit and duplex outlets intstalled along perimeter. Wire for duplexes will obviously be run in the conduit. Was thinking about using plastic tie straps to secure coax cable along conduit and at certain points putting a coax outlet in a 2 gang box along with the duplex. would this be ok?
Minus08 is offline   Reply With Quote
Old 02-14-2012, 06:00 PM   #2
Master Electrician
Yes, if you provide a divider in the box between the two.
brric is offline   Reply With Quote
Old 02-14-2012, 06:02 PM   #3
It was a dark and stormy
Yoyizit's Avatar
Can you post a link to a suitable divider?
Old 02-14-2012, 06:26 PM   #4
Master Electrician
Depends upon the type of box and the manufacturer.
Old 02-14-2012, 06:51 PM   #5
Master Electrician
http://www.tnb.com/contractor/docs/sc_indoorboxes.pdf
Page A34.
The Following 2 Users Say Thank You to brric For This Useful Post:
Minus08 (02-14-2012), plummen (02-14-2012)
Old 02-14-2012, 07:08 PM   #6
Would you just use a NM cable clamp to secure the coax to the box?
ANd the part about using cable ties is ok?
Old 02-14-2012, 07:09 PM   #7
bbo
http://lmgtfy.com/?q=2+gang+box+divider
I'd think the big orange box or ld blue would have them.
or menards or whatever local place you have.
bbo is offline   Reply With Quote
Old 02-14-2012, 07:11 PM   #8
If this is a brand new box, I'd suggest getting a 2 gang mixed box. It has a fully enclosed 1 gang box for the 120/240 side and a low voltage opening for the other side.
a_lost_shadow is offline   Reply With Quote
The Following User Says Thank You to a_lost_shadow For This Useful Post:
bbo (02-14-2012)
Old 02-14-2012, 07:18 PM   #9
Just found this:
Arlington's recessed STEEL combination power and low voltage TV BOX™ is the best way to mount flat screen TVs flush against a wall. It's also great for hotel and other settings where furniture and/or appliances need to be pushed close to the wall. Plugs and connectors stay inside the box, without extending past the wall. Designed for use in commercial construction where metal raceway is used,
Steel TV BOX provides power and/or low voltage in one or more of the openings. TV BOX is available in 2-, 3- and 4-gang styles. We have a box for almost any new or old work application!
  • Steel box with non-metallic paintable white or black trim plate
  • Easy to install, secure installation
  • Mounting wings on two- and threegang styles hold boxes securely against the wall in retrofit projects
  • Boxes screw-mount to stud in new construction
  • Optional covers for unused boxes
  • UL Listed
Website:
http://www.markertek.com/Parts-Acces.../TVBS505.xhtml
Youtube video:
http://www.youtube.com/watch?v=kBtpH9-Bwgs
Old 02-14-2012, 07:21 PM   #10
are you asking me if I have a brand new box? I don't have any boxes yet. trying to determine what to use thats why i posted here.
Old 02-14-2012, 08:07 PM   #11
Electrical Contractor
Are you required to use conduit?
Boxes are made like that for romex also.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 02-14-2012, 09:04 PM   #12
Minus,
Sorry, I was skimming and missed the part about the run being completely new and not a modification to an existing. If you just need outlets, i.e. not mounting a tv to the box, you can use a box similar to the following:
Since the coax is going in the open side you don't need to worry about getting the coax to go through the clamps or the bend radius of the coax.
As for strapping the coax to the conduit, that's not allowed by NEC 820.133(B).
Old 02-15-2012, 05:47 AM   #13
Yes have to use conduit. The run is going to be horizontal in an unfinished basement along a block wall. see photos below I already added. You can see I Already added 1st box around the corner from the pamel GFCI. Eventually gonna continue to the right and install more duplex outlets and want to install 2 coax outlets
and lostshadow as you can see from my photos, I cant use a plastic new work box that attaches to studs because I do not have any studs.
Old 02-15-2012, 10:57 AM   #14
Yoyizit's Avatar
Thanks.
I was wondering whether the divider is just supposed to provide a physical barrier or to also provide shielding to prevent the 60 Hz from getting into the coax.
Old 02-15-2012, 05:30 PM   #15
Even though the coax is shielded, I would never place any low or no voltage wire next to high voltage carrying wire.
I'm not saying it will or will not happen, but placing the coax next to the outlet wires can induce voltage into the coax. Could cause picture quality or sound issues.
Best to stay at least a foot from the house wiring. Also, its not advisable to parallel coax, speaker wire, data cable next to house wiring for long distances. Try to keep the low voltage wire away from the high voltage.
Earnie is offline   Reply With Quote
Pre-wired coaxial cable mapping & digital antenna set up BadHand Electrical 6 10-30-2011 10:37 PM
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 04:36 PM
10 gauge outdoor power line and security camera cable (not coaxial) vahlesm Electrical 4 05-02-2010 12:30 AM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
Will reverse polarity trip breaker?? Duane 70 Electrical 60 12-05-2008 11:18 PM
