Can A Baseboard Heater Circuit Be 30 AMP? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-24-2011, 02:39 AM   #16
Code05's Avatar
Rewards Points: 1,104
Originally Posted by Missouri Bound View Post
Actually I would put each room on it's own breaker. And I would install a sub panel just for the baseboard heat. I'm sure it's not code that you have to do it that way, but I would prefer to have each room on it's own circuit. A dedicated disconnect is how I would like it to be. Just my opinion.
Not all of us are rich and can afford to waste money, time, and resources.
Code05 is offline   Reply With Quote
The Following User Says Thank You to Code05 For This Useful Post:
stickboy1375 (04-06-2013)
Old 09-24-2011, 04:17 AM   #17
Rewards Points: 1,192
Electric is always the place to cut on a remodel.
bobelectric is offline   Reply With Quote
Old 09-24-2011, 04:46 AM   #18
Code05's Avatar
Clarify, nobody said cut corners, just be efficient.
The Following 2 Users Say Thank You to Code05 For This Useful Post:
Speedy Petey (09-24-2011), stickboy1375 (04-06-2013)
Old 09-24-2011, 05:00 AM   #19
Cut corners on infrastraucture ,wire to minimum code.you'll be fine.
Old 09-24-2011, 05:18 AM   #20
Code05's Avatar
Again, a response: but no solution or suggestion of a answer.
Your point is???
Old 09-24-2011, 08:22 AM   #21
Rewards Points: 1,492
deleted
Old 04-05-2013, 05:51 PM   #22
Rewards Points: 83
I can't believe it has been a year and a half since this thread!
Well, I have finished wiring my basement. I have inspection in a couple weeks.
I decided to go with two 20A circuits.
I put the theater and the east bedroom on one circuit. Came to 3500 watts, 14.8 Amps. This is 73% utilization, so under the 80% mark.
I put the hall and other bedroom on the second circuit. Comes to 1750 watts, 7.3A. I also put a drop on the other bedroom in the basement for further expansion if desired. That's why I left more capacity on this circuit, as I have an already finished room I may add another heater on.
danielrg is offline   Reply With Quote
Problem with 240V Elect Baseboard Heater JRHP Electrical 4 10-04-2010 09:30 AM
Min distance from baseboard hotwater heater capslock General DIY Discussions 2 05-25-2010 07:31 AM
Wiring a 240V baseboard heater T-stat criggs Electrical 3 05-10-2010 08:27 PM
Covering/Blocking a Baseboard Heater jjorczak HVAC 0 11-20-2009 07:22 AM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 07:59 PM
