Can Armorlite MC Be Exposed? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-11-2012, 10:50 PM   #1
Rewards Points: 1,062
Question
can Armorlite MC be exposed?
i want to install a simple handy box on a baseboard that rests on a plaster wall, which would require about 3" of exposed cable if i were to avoid the hassle of cutting and bending conduit. since i do have a considerable amount of 14/2 armorlite MC, i was wondering if i can just use that and leave it exposed, i.e. if the metal cladding does act as a legal conduit.
thanks
Old 09-12-2012, 05:59 AM   #2
Julius793's Avatar
thanks
Won't look nice but in most cases code compliant.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
The Following User Says Thank You to Julius793 For This Useful Post:
amakarevic (09-12-2012)
Old 09-12-2012, 11:52 AM   #3
it's OK, it will be only a few inches. thanks. plus it is a temporary solution until i tear the room down.
Old 09-12-2012, 12:12 PM   #4
Julius793's Avatar
Yeh then for sure it's not an issue
Old 09-12-2012, 12:18 PM   #5
Rewards Points: 174
330.10 Uses Permitted.
(A) General Uses. Type MC cable shall be permitted as
follows:
(1) For services, feeders, and branch circuits.
(2) For power, lighting, control, and signal circuits.
(3) Indoors or outdoors.
(4) Exposed or concealed.
(5) To be direct buried where identified for such use.
(6) In cable tray where identified for such use.
(7) In any raceway.
(8) As aerial cable on a messenger.
(9) In hazardous (classified) locations where specifically
Old 09-16-2012, 11:48 PM   #6
Don't look too bad. Kinda industrial...
Old 09-17-2012, 06:04 AM   #7
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
I would have just pushed the box closer to the floor.
Exposed WIRING ON BOTTOM OF JOISTS. pp2815 Electrical 12 05-01-2012 02:32 AM
Exposed sheet metal questions ohman Roofing/Siding 6 12-31-2010 10:46 AM
Exposed fiberglass insulation in partially-finished basement skysurf Building & Construction 1 04-11-2009 09:40 AM
partially exposed rafters rtoni Building & Construction 1 08-13-2008 04:45 PM
