Can Anyone I.D This 3 Pole Switch?? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-30-2008, 11:32 PM   #1
Can anyone I.D this 3 pole switch??
Hi just wanting to replace this worn out 3 pole light switch.Funny thing is,is that it has a black wire that "plugs"into the left top of the back of it.I have tried home centers but no luck.Anyone know what type of 3 pole this is and where I can get one??Thanks!
Any help would be great!
Matt
remlu is offline   Reply With Quote
Old 12-01-2008, 02:03 AM   #2
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
Matt
Is this a 3 way switch? Are there 2 switches that controal one or more lights?
jamie
jamiedolan is offline   Reply With Quote
Old 12-01-2008, 07:17 AM   #3
Not sure, can't tell from the pic, they all look the same. Just get a levition switch or something similar.
rgsgww is offline   Reply With Quote
Old 12-01-2008, 08:03 AM   #4
Rewards Points: 2,350
This is not a 3-pole switch, but rather a 3-way switch. No wonder you couldn't find it a the home center! You had that poor guy scratchin' his head. The wire on the black screw and the wire plugged into the back left hole are meant to be wired together, since the screw and hole are electrically continuous.
You should kill the power, then take the wire from the black screw and wire nut it together with the wire from the hole, and add a short piece of wire to re-attach to your new switch on the black screw. The other two wires should land on the two brass screws of the switch, it doesn't matter in what order.
Old 12-01-2008, 10:45 PM   #5
Thanks for the info, I miss stated 3 pole and 3 way.The switch controls the garage lights. 2 switches for one light.All the other 3 way switches in my house are like this one.I will try the Levition switch out.
Old 12-01-2008, 11:23 PM   #6
DIY'er
jamiedolan's Avatar
I would spend a couple extra bucks for a "premium" switch. They are a bit more expensive, but are much better quality. They used premium style of switches in my house, and even in heavy use areas, very few are really worn out after 45 years, and they all still function, just a couple are a bit sticky or do not make as good of contact as they once did.
A premium 3 way is about $3 to $4 in the pass and seymour brand. Should be about that same price in leviton also.
jamie
Old 12-02-2008, 05:46 AM   #7
dSilanskas's Avatar
Matt
Its a P&S 3 way
dSilanskas is offline   Reply With Quote
Old 12-02-2008, 11:11 AM   #8
Do you know where I can get a P&S 3 way?? Thanks
Old 12-02-2008, 11:54 AM   #9
Go to Home Depot or Lowes. They should have this in stock. Ask for a three-way switch (single pole double throw).
pbservano is offline   Reply With Quote
Old 12-02-2008, 06:52 PM   #10
Rewards Points: 886
You say "single pole, double throw" to any HD or Lowes employee, and you're most likely going to get that look
Ultrarunner2017 is offline   Reply With Quote
Old 12-02-2008, 07:35 PM   #11
To the original poster:
Give it a try first by asking the hardware customer service, most of these folks are knowledgeable enough to know what is a three way switch. If they give you a look. Print a picture of the switch and explain the purpose of the switch. Most of the time they will know. At least you give it a try. Ensure the power or breaker is off prior to disconnecting the old switch and installing the replacement switch. If not sure of what you're doing better off calling a licensed electrician.
Old 12-02-2008, 08:52 PM   #12
It's a simple 3 way switch. Any brand is tthe same. Note the COMMON wire on the old switch or you will be back asking how to wire it
220/221 is offline   Reply With Quote
Old 12-03-2008, 01:01 AM   #13
DIY'er
jamiedolan's Avatar
Home depot basic entry level 3 way:
http://www.homedepot.com/webapp/wcs/...ctId=100356976
The higher end $4 version:
http://www.homedepot.com/webapp/wcs/...ctId=100356824
Menards carries P&S brand in the midwest, but as others have said it really doesn't matter what brand you get unless your trying to get the switches to all physically look the same...(some are wider than others, etc.)
Jamie
Converting a single pole switch to a 3 way Rze Electrical 7 09-13-2011 12:39 PM
Converting a single pole switch to a 3 way Rze Electrical 9 05-02-2011 10:10 AM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 07:59 PM
Single pole with white on the switch grog Electrical 4 08-10-2008 07:56 PM
Anybody ever seen a 5A 250V single pole switch? jayp Electrical 5 08-04-2008 05:41 AM
