Old 06-04-2011, 04:31 PM   #1
can #6/2 NM wire (White,Black, bare wire ground be used for spa ?
Question: My home was built in 1996. Has dedicated circuit of 240 volt with NM wire (1 hot-black, one neutral-white, and a bare ground. All three wires are same guage (#6). I have been told that this set up can be used by installing a 2 pole 50 amp gfci in my 200 amp box and using the white neutral as a hot lead and using bare wire as ground, assuming all equipment is 240 volt. There are companys which sell spa packs to order with 3 wire hook up. Is this idea safe?legal? or am I going to have to go to a 4 wire set up? Any feed back from knowledgable electricians will be greatly appreciated. Thanks, T.T.p.s. Heater will be a 5.5kw
T-texas-43 is offline   Reply With Quote
Old 06-04-2011, 07:29 PM   #2
Electrical Contractor
kbsparky's Avatar
IF you mark or label that white conductor to another color, such as black, red, or blue, AND there is no neutral required for the tub, then it should be sufficient.
-KB
Old 06-04-2011, 09:23 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
It depends on the spa.
This is not an "older" circuit. It is simply a straight 240v circuit.
Speedy Petey is online now   Reply With Quote
What to do with ground wire? scottyv81 Electrical 4 01-29-2011 11:11 AM
neutral wire became ground? okedomantakeshi Electrical 18 12-29-2009 04:18 AM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 07:30 PM
