Can A 30 Amp Inlet Be Connected With #6 Wire? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-28-2011, 06:25 AM   #1
Can a 30 amp inlet be connected with #6 wire?
Two quotes. One Electrician says I can't connect a 30 amp power inlet (for port. generator) with #6 wire because it violates the manufacturer's recommendations. He says the largest is #8. The other electrician was all set to connect a 30 amp inlet with #6 wire.
I already asked about what is best wire size for a 95 foot run from power inlet to panel here about 3-4 days ago.
Does this make sense? The differing plans and responses from different contractors makes it very confusing.
Thank you again.
Npkr01 is offline   Reply With Quote
Old 10-28-2011, 07:20 AM   #2
Electrician
SD515's Avatar
Rewards Points: 504
#6 is more than adequate for carrying 30 amps. The ‘30 amp power inlet’ may not physically be able to accept such a size wire, in which case you can pigtail #8’s or #10’s between the ‘power inlet’ and the #6 if the inlet box is big enough to accommodate the connections. You may also have to use pigtails at the other end where the #6 is going to attach to a breaker. If you don’t already have the #6, I’d get some #10.
Kyle
The Following User Says Thank You to SD515 For This Useful Post:
Npkr01 (10-28-2011)
Old 10-28-2011, 10:25 AM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
I agree. Why are they even spec'ing 6 or #8??
Old 10-28-2011, 10:52 AM   #4
liscenced electrician
Rewards Points: 538
He had a post a post about it a couple days ago. He's doing 30 amp now but wants to leave provisions to upgrade later.
Use a blue wire nut and pig tail on #10 wires
jimmy21 is offline   Reply With Quote
The Following User Says Thank You to jimmy21 For This Useful Post:
Npkr01 (10-28-2011)
Old 10-28-2011, 11:08 AM   #5
Rewards Points: 1,494
It's perfectly okay to string an oversized wire for futureproofing or to reduce voltage drop over a longer run. Just need to put in a breaker rated at no more than 30 amps for a 30 amp receptacle.
The Following User Says Thank You to AllanJ For This Useful Post:
Npkr01 (10-28-2011)
Old 10-29-2011, 02:05 PM   #6
Problem solved-thx
Thank you for the replies.
The electrical contractor that I favored to do the work agreed to pigtail the 30 amp inlet onto the #6 run, which I politely and tactfully suggested to him after getting your responses here.
Your help is much appreciated.
which GFCI to buy? mike932 Electrical 138 05-15-2011 04:38 PM
Box fill and wire nuts zephed666 Electrical 7 05-02-2011 12:51 PM
2 wire switch connected to 3 wire outlet pacowboy78 Electrical 4 08-23-2010 07:25 PM
3-way switch help amit Electrical 17 02-15-2010 03:17 PM
New light switch burns out dsbutler71 Electrical 12 09-05-2007 07:34 PM
