Can 15 A Light Switch Be Used On A 20 A Circuit? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-21-2010, 05:27 AM   #1
Can 15 A light switch be used on a 20 A circuit?
I've heard that 15 amp receptacles are acceptable for 20 amp circuits. Does the same hold true for standard 2 way switches. The circuit will carry just one light, a 150 watt flood light on wall of attached garage. The circuit is 20 amp for convenience when running wires and to lessen load on the 15 amp lighting circuit. Switch reads: "15A-120vac only." Thanks for any clarification.
Mi Feller is offline   Reply With Quote
Old 07-21-2010, 06:28 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 554
Yes!!
Old 07-21-2010, 06:42 AM   #3
Rewards Points: 1,216
Read the switch information one more time. 15amp 120v only.
You answered your own question. Follow the manufacturers directions you can never go wrong. OH yea you can hook it up to 20a but why?
There's a lot of things you can do to make something work but it might not be correct. buy a 20amp switch.
COLDIRON is offline   Reply With Quote
Old 07-21-2010, 06:47 AM   #4
Just call me Andrew
Rewards Points: 1,020
Originally Posted by jbfan View Post
Yes!!
I agree. As long as the load passing through the switch will be 15A or less, you are fine.
Andrew
secutanudu is offline   Reply With Quote
Old 07-21-2010, 08:13 AM   #5
Licensed electrician
Rewards Points: 1,794
That switch could safely control up to a 15 amp load. The rating is not a circuit limit.
Old 07-21-2010, 08:26 AM   #6
This is a recording. Always follow Manufacturer's instructions.
Old 07-21-2010, 08:30 AM   #7
The OP is switching a 150 watt light. 150W/120 = 1.25 amps. Well less than 15 amps that the switch is rated for.
Old 07-21-2010, 08:34 AM   #8
Electrician
Proby's Avatar
He would be.
Proby is offline   Reply With Quote
Old 07-21-2010, 08:35 AM   #9
Just call me Andrew
The manufacturer's instructions say nothing about breaker size.
Andrew
Old 07-21-2010, 08:42 AM   #10
15a switches are used all the time on 20a circuits
There is no need to buy a 20a switch unless the load you are switching is close to or greater then 15a
A 15a switch on a 20a circuit does meet code
Old 07-21-2010, 04:05 PM   #11
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,974
Bingo!
The Following User Says Thank You to Speedy Petey For This Useful Post:
Jim Port (07-21-2010)
Old 07-21-2010, 08:29 PM   #12
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 132
For a light, it is probably safe given the load will never really change, but personally I would not do it. If that switch controls a receptacle, then no way.
Easiest is just change the breaker to 15 amps.
Old 07-21-2010, 08:44 PM   #13
jbfan's Avatar
Rewards Points: 554
Why? Do you have 20 amp receptacles?
I doubt that you would ever plug anything in that pulled 15 amps.
Old 07-21-2010, 08:59 PM   #14
I doubt I have single 20 switch in this house are any other house/Apt I have lived in
I've yet to have any light switch that would control anywhere near 1800w
Old 07-22-2010, 06:06 AM   #15
Thank you for the assorted responses. It's good to know the 15A refers to load and not breaker size. Can buy 20 A switches but not locally. Question was in part out of curiousity. Thank you.
3-way switch circuit w/light on each end. rcraighead Electrical 6 06-01-2010 10:57 AM
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 02:44 PM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
new light and switch problem please help rebelbull Electrical 1 10-02-2009 06:39 AM
Replacing light switch in series wired home - help! kellykate Electrical 6 04-16-2009 06:37 PM
