Old 08-10-2012, 01:17 PM   #1
Can 14 gauge wire be used on 20 amp circuit?
I am redoing my basement, and i am making the electrical runs for the recessed lights in the ceiling. I am using 14 gauge wire, and i have 16 recessed lights with 65 watt bulbs in them, however they are rated at 75 watts max. assuming someone after us may put in the max bulb, the total watts would be 1200, equaling 10 amps. When all of the new wiring is done, i am going to have an electrician connect the circuits to the circuit breaker (using 15 amp breakers) however since i am not comfortable doing this myself, and i would like to use the lights now, can i connect them to the existing 12 gauge wire (this will not overload the breaker... i already checked what else was plugged in to the electrical outlets).
to recap:
The power draw will only be 10 amps at MAX. capacity
existing wiring is 12 gauge/ 20 amp breaker
electrician WILL connect 14 gauge wire to breaker using 15 amp breaker
*THIS WILL BE TEMPORARY*
diyer111 is offline   Reply With Quote
Old 08-10-2012, 01:28 PM   #2
Civil Engineer
You can probably connect the 12 gauge permanently, unless you have something else on the circuit that will overload a 20A circuit. My basement has mixed lighting/outlet circuits on 12 gage wire, so far as I know there are no specific NEC rules prohibiting mixed outlet/lighting circuits in the basement. There are rules about GFCI for basement locations, but those do not pertain to mixing lighting and outlets.
Daniel Holzman is online now   Reply With Quote
Old 08-10-2012, 01:41 PM   #3
Missouri Bound's Avatar
There are a lot of "temporary" things that are never changed and become permanent. If you use both 12 and 14 ga wire on the same circuit the opd must be sized for the smaller wire. It's not allowed....but obviously it will work. The purpose of the breaker is to protect the wire....period.
Do you want it your way or the right way?
Old 08-10-2012, 01:54 PM   #4
The 12 gauge wire is the old (existing) wire in the basement that will be replaced by the electrician when he connects to new 15 amp circuits. my wuestion is/was can i temporarily tie into this wire with 14 gauge (15 amp) wire untill electrician comes.
Old 08-10-2012, 03:31 PM   #5
A 15 amp breaker is the maximum size to protect 14 ga wire.
M Engineer is offline   Reply With Quote
Old 08-10-2012, 05:32 PM   #6
kevinp22's Avatar
think of it this way. if there is a high resistance short and it draws 19 amps through the 14 gauge wire for hours/days on end, it wont end well or at least the new wire you installed will be damaged.
kevinp22 is offline   Reply With Quote
The Following User Says Thank You to kevinp22 For This Useful Post:
Missouri Bound (08-10-2012)
Old 08-10-2012, 05:38 PM   #7
Pure Genius
Im just curious why you wont make final terminations in the panel. Hell youve done everything else so why not land it?
Dierte is offline   Reply With Quote
Old 08-10-2012, 06:49 PM   #8
Master Electrician
Where are you from. You'd be allowed to do it in Canada. They've created a silly loophole/doesn't make sense bit of code in the new book that makes it grey area depending on conditions.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 08-10-2012, 07:31 PM   #9
E2 Electrician
stickboy1375's Avatar
14 AWG is rated for 20 amps...
We just cant use it at that rating.
The Following User Says Thank You to stickboy1375 For This Useful Post:
1957classic (08-13-2012)
Old 08-13-2012, 11:14 AM   #10
first, i am not a qualified electrician, and i have been working on all lighting/ outlets NO possible power to them (not connected to a power source). second, even when the reaker is turned off, you still have the power coming in from the street equaling 240 volts... not something to be messed with.
Wire Gauge and Circuit Breakers Red Truck Electrical 21 01-21-2012 07:33 AM
Kitchen circuit re-design - Existing is a mess darlingm Electrical 5 12-31-2011 10:45 PM
ceiling fan wicked97 Electrical 4 08-21-2011 09:12 AM
12 and 14 gauge wire on one circuit whatrymes Electrical 4 04-17-2011 10:32 AM
What wire gauge for plumbing ground? bob22 Electrical 4 04-04-2010 08:01 PM
