Calibrating Insulation Continuity Testers - Electrical - DIY Chatroom Home Improvement Forum
Old 02-13-2009, 05:15 PM   #1
calibrating insulation continuity testers
hi i was wondering if anyone can help me, to calibrate a insulation continuity tester on the 3 ohm range to 1 ohm . what can you use to do that and how to make one
steve halliday is offline   Reply With Quote
Old 02-13-2009, 10:13 PM   #2
Originally Posted by steve halliday View Post
insulation continuity tester the 3 ohm range to 1 ohm
how to make one
Please 'splain.
Old 02-14-2009, 02:07 AM   #3
Originally Posted by Yoyizit View Post
Please 'splain.
i'm not sure but i think you need a 1 ohm resistor or some thing and when you put your tester on the 3 ohm range it should read 1 ohm. if not you adjust
Old 02-14-2009, 04:43 PM   #4
Post a photo.
Old 02-14-2009, 08:13 PM   #5
Electrician
As a commercial/industrial service electrician, I have seen, used, or at least heard of pretty much every piece of test equipment imaginable, but I have never had to calibrate an insulation tester.(I am assuming you meant an insulation and continuity tester, I have never heard of an insulation continuity tester)
I own an insulation tester (megohm meter) and use it regularly, but to my knowledge there is no way to field calibrate it.
I also own several different types of continuity testers and again, no calibration needed.
If you could post the make and model number of your tester we may be able to help, otherwise I am just confused.
EBFD6 is offline   Reply With Quote
Old 02-14-2009, 08:18 PM   #6
Insulation is about lack of electrical continuity.
If you're talking about a megger, I guess you could wire 10 ea., 10 meg +/- 10% resistors in series and get a 100 meg +/- 3% composite resistor.
If you wire 100 ea. you get 1000 meg +/- 1% resistor.
Ten will cost you 50˘ from this place
http://www.allelectronics.com/index....eg+ohm&x=0&y=0
but I couldn't find a tolerance spec or max voltage rating (usually it's 500v) on their webpage.
Old 02-14-2009, 10:04 PM   #7
thanks for your help
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Old home insulation woes nowwhatnapster Building & Construction 15 11-02-2008 11:59 PM
Insulation over Attic Walkway BigJimmy Building & Construction 4 06-23-2008 02:13 AM
attic insulation question dderolph Building & Construction 10 11-03-2007 05:21 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
