Old 05-25-2011, 04:40 PM   #1
Calculations for voltage drop of wire
I was just talking with a design tech that I know and was comparing voltage drop data. I was surprised how far apart we were and it seems he uses a different method for the calculation. Mine seem to arrive at the same number as about any calculator online but his were up to 3X as much voltage drop.
Just curious what formula and tables references you use? Let's leave the actual application and and loads and such out of it and concentrate on the actual value. I would also like to know if you guys look mostly at 90c for service entrance wire or if you build for 75c?
viper is offline   Reply With Quote
Old 05-25-2011, 05:34 PM   #2
Licensed electrician
Were you using the total length of the circuit which is the out and back distance or only out? Were you using the same design load?
Your wire needs to be sized based on the lowest rated part of the system. You will not find terminations rated 90C, but the wire can be derated from the 90C ratings.
Old 05-25-2011, 05:48 PM   #3
Because of the length of run, wire heat is not as much an issue as Vdrop. Loads are being calculated phase - phase with equal Vdrop between them so of course it would double.
I am more or less looking for hard calculations here.
As for the temp rating, I thought one could use a higher current rating but lower temp rating to offset operating higher temp wire? Is that not the case? Obviously the NEC will limit the current in the conductor to a safe level anyway and right now our wires are looking to run about 55C but Vdrop is a concern. I am working back through the physics of it and going to compare the NEC book to actual periodic table data just too see if there are engineered margins there. Sometimes too many compounded margins ends up getting ridiculous IMO.
Old 05-25-2011, 07:57 PM   #4
Lic Elect/Inspector/CPO
See 210.19 A1 FPN #4
The note says that the 3% is just for a branch circuit. For the Feeder and the Branch circuit its a total of 5%
If you supply the information, I will do a calc and we could compare results.
NJMarine is offline   Reply With Quote
Old 05-25-2011, 08:35 PM   #5
Thanks!
Example would be:
4/0 Aluminum 240V 1ph
500ft from transformer to load
150A load
Another is 500mcm Al, 240V 1ph
500ft as well
300A load
Oh, these would both be underground in conduit installations so I am figuring 15-20C ambient.
Old 05-25-2011, 08:50 PM   #6
We do not use temperature when figuring voltage drop. However when choosing the wire size needed to avoid temperature problems (in conduit, in free air, kind of insulation, etc) we might already come up with a wire size large enough to not suffer excessive voltage drop.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 05-25-2011, 08:54 PM   #7
Originally Posted by viper View Post
Thanks!
Example would be:
150A load
500ft as well
300A load
#1 i get -15V(6.25%), to get under 5% i show needing 300kcmil AL, for 3% i show 500kcmil AL
#2 i get -12.72V(5.3%)to get under 5% i show needing 600kcmil AL, for 3% i show 1 run of 900kcmil AL, 2 runs of 500kcmil AL, 3 runs of 300kcmil or 4 runs of 250kcmil AL
Techy is offline   Reply With Quote
Old 05-25-2011, 10:24 PM   #8
Huh, that is yet another value. do you happen to have the equation that was used to calculate that?
One that seems to be floating around the net that I am not sure I agree with is (2*L*R*I)/1000 That produces 12.06% for the 4/0 using .0804/K for resistance. The NEC books I think is .1 ohms for 4/0 so there is a little discrepancy there.
Old 05-25-2011, 10:39 PM   #9
Missouri Bound's Avatar
My turn....300 mcm copper....................500 mcm alum.
Old 05-25-2011, 11:19 PM   #10
http://www.electecinc.net/example1.pdf
http://www.electecinc.net/example2.pdf
Old 05-26-2011, 06:49 AM   #11
#1 500 kcm
#2 900 kcm
Old 05-26-2011, 12:20 PM   #12
J. V.'s Avatar
http://www.liteco.ca/Portals/_Rainbo...calculator.htm
Old 05-26-2011, 05:07 PM   #13
http://www.csgnetwork.com/wiresizecalc.html
I use this often.
which GFCI to buy? mike932 Electrical 138 05-15-2011 05:38 PM
Box fill and wire nuts zephed666 Electrical 7 05-02-2011 01:51 PM
Outlet With Swith and Older (White, Black, Red) Wire CaptChaos Electrical 18 09-15-2009 12:17 AM
New Stove, old wires - 2 wire vs 3 wire DIYGST Electrical 22 03-02-2009 05:13 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
