Calculating Overcurrent Protection On The Primary Side. - Electrical - DIY Chatroom Home Improvement Forum
Old 02-25-2011, 10:10 AM   #1
Calculating Overcurrent Protection on the Primary Side.
3 KVA dry type transformer (Calculating Overcurrent Protection on the Primary Side)?
I will run #12 THHN wire as we usualy do but the current on the load is some constant at about 1.5 amps for a low voltage power supply and the rest of the panel is floating at about 15 amps max using 480 single phase on the line side of the 3KVA.
Just wondering if I can calculate exactly what the transformer is going to draw?
Carandorandy
Carandorandy is offline   Reply With Quote
Old 02-25-2011, 11:37 AM   #2
Rewards Points: 204
6.25 amps. You are in the wrong forum.
Tags
overcurrent , transformer
3 KVa / formula Carandorandy Electrical 6 02-26-2011 07:17 AM
Timing for rebuilding of side entry: Help! navi_jen Remodeling 0 06-16-2010 10:02 AM
Should I use a vapor barrier on each side? Hossenfeffer Building & Construction 3 04-09-2010 10:12 PM
Calculating load - 240 load question jamiedolan Electrical 5 10-04-2008 05:26 PM
Side By side refrigerator Susie Q Appliances 6 08-31-2007 03:26 PM
