Calculating Load - 240 Load Question - Electrical - DIY Chatroom Home Improvement Forum
Old 10-04-2008, 03:24 PM   #1
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
Calculating load - 240 load question
I ran ever appliance I would possible run, and then threw in a couple extra heavy resistance appliances for good measure and put a clamp meter on my each side of my box so see what I was drawing.
I maxed out at right about 55A on each side of the box. My question is if I added a hot tub, and for the sake of conversation lets say it is on a 40A breaker and it draws the full 40A (I know it would not really max out the circuit).
Can a 40A double pole breaker draw 40A from each side of the panel or can it only draw a total of 40A (20A from each side)?
I don't have anything 240V that is hooked up that I know the draw of, so I don't have any way of testing this right now.
My thought is that it could only pull 20A per side max, so then my load would be 55A per side + 20A = 75A per side when I am maxed out. If this is correct, then I would only be within 75% of my 100A capacity even with what is really high usage for me.
Jamie
jamiedolan is offline   Reply With Quote
Old 10-04-2008, 03:26 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,822
If it is 40 amps @ 240v it is 40 amps PER SIDE. NOT 20 amps per side.
Old 10-04-2008, 04:00 PM   #3
Electrician
SD515's Avatar
Rewards Points: 504
Matter of fact Jamie per your scenario, in theory (and sometimes in practice) you can physically separate the two halves and have 2 individual single pole, 40 A breakers.
Kyle
Old 10-04-2008, 04:36 PM   #4
DIY'er
jamiedolan's Avatar
Now that you say it this way it makes perfect sense to me. The setup where there are 2 single pole breakers bonded together, both switches attached to each other.
Wow a hot tub sure can draw alot of power compared to many 120 appliances.
Jamie
Old 10-04-2008, 06:24 PM   #5
Electrician
SD515's Avatar
Rewards Points: 504
Yep. Interesting when ya think about it, huh?
Kyle
Old 10-04-2008, 06:26 PM   #6
Electrician
Jamie
Yes, but it will cycle, just like an electric range.
chris75 is offline   Reply With Quote
Another Load Bearing Question - Modular Homes ch3howard Carpentry 2 08-17-2008 10:21 PM
framing, expanding wall opening wall - load bearing? nave Remodeling 5 01-23-2008 04:44 PM
Rated load question blowmax10 Electrical 8 09-29-2007 07:47 PM
Load Calculation ? RM575 HVAC 9 07-04-2007 01:37 PM
% total roof load on interior bearing wall? Grommet Building & Construction 1 03-29-2007 08:37 AM
