Cables Too Short In New Subpanel - Electrical - DIY Chatroom Home Improvement Forum
Old 09-13-2011, 05:13 PM   #1
Rewards Points: 27
Cables too short in new subpanel
I am replacing the service panel in my barn. This is a subpanel that runs off of the panel in the main house.
Here's my question. The cables that carry power from the house (3 large aluminum cables enclosed in a metal conduit) are not quite long enough. In the new panel, the two "hot" cables only reach about halfway up, and I need to connect these up at the top where the main breaker is (to clarify, the main breaker in the new panel is only being used as a disconnect).
It would be impractical to pull new cable from the house.
Solutions?
Eric
mn1247 is offline   Reply With Quote
Old 09-13-2011, 05:29 PM   #2
can the new sub be mounted upside down? it should state on the label the allowed positions.
CuHead is offline   Reply With Quote
Old 09-13-2011, 05:42 PM   #3
Code05's Avatar
Rewards Points: 1,104
As said, flip the panel if possible, or splice a short piece.
Code05 is offline   Reply With Quote
The Following User Says Thank You to Code05 For This Useful Post:
NJMarine (09-13-2011)
Old 09-14-2011, 07:09 AM   #4
Rewards Points: 27
Thanks for the advice. I'll look into flipping the panel.
It's the "splice a short piece" that I'm wondering about - I don't know how to do this. I know there are wing nuts for small wires, but how do I splice a heavy cable? Is there a device for this?
Eric
Old 09-14-2011, 07:18 AM   #5
Code05's Avatar
http://www.ilsco.com//ProductsDetail...yLHJkJd44fw%3d
Old 09-14-2011, 08:10 AM   #6
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,216
The 100 amp GE main breaker panel that I bought for a sub is definitely rated to me turned upside down. If the panel you have or are considering is not, I would get a different panel and not use splices. I am sure there are brands other than GE that have that feature.
Coastal South Carolina
Old 09-14-2011, 08:20 AM   #7
Code05's Avatar
Generally any panel that has the main breaker in a horizontal position can be flipped.
Vertical no.
MLO yes.
Several Questions...leading to Garage Subpanel willstutely Electrical 5 01-03-2012 01:38 PM
wiring subpanel wire too short kenmore Electrical 8 06-02-2011 03:34 PM
Problems with Square D Subpanel bltglt507 Electrical 16 12-04-2009 08:44 PM
A few slightly different questions on subpanel wiring. Chris Dopp Electrical 8 06-26-2009 09:45 PM
