A local church recently purchased a spring cable management wheel for getting electric to a truss that can be raised and lowered over the stage.
I became involved in the project after the fact and am trying to figure out if the company that sold them the wheel, sold the right one. I handle the lighting as a volunteer for weekend services and am trying to figure out the maximum number of lighting circuits the truss is capable of having.
http://www.conductix.us/products/cab...powerreelc2ae/
The whip for the wheel has 12 - 12 gauge stranded wires on it.
My question pertains to how many usable circuits that can provide based on the following:
There are two winches on the truss that raise and lower anything hung from the truss, usually a projection screen. These require 3 wires each, plus ground.
I wanted to have a single 208-240 service on the truss along with as many 110 circuits as possible.
Where I am confused is knowing the size of the wire is fixed at 12 gauge, how does a MWBC work in this setup?
Can we do
208/220 circuit #1
1 - 110 phase 1
1 - 110 phase 2
1 - 110 neutral (shared with cir #2)
208/220 circuit #2
1 - 110 phase 1
1 - 110 phase 2
1 - neutral (shared with cir #1)
So that uses 5 wires.
Then for the winch motors which require independent control.
Motor #1
1 - up
1 - down
1 - neutral (shared with motor #2 neutral)
(The positive comes from the wired remote switch)
Motor #2
1 - up
1 - down
1 - neutral (shared with motor #1 neutral)
That uses another 5 wires, leaving me with 2 left.
Can the electrician make these one 110 circuit, sharing the neutral of the motor circuits and a ground?
The issue (IMHO) is the company that sold the wheel, didnt listen to the requirements and wasnt responsible for the installation of the wheel.
Note: The installation will be done by a local electrician. What I am trying to figure out is if this wheel will do what we need it to do, before I haul the thing up in the ceiling...its about 60' up there thru a small hatch.
