Cable Under Floor Joists - Electrical - DIY Chatroom Home Improvement Forum
Old 01-19-2012, 02:39 PM   #1
Cable under floor joists
Can cables be run perpendicular to joists in an open basement? Can I staple at each joist to reach the panel or do I need to drill and pull wires through? We're in NY.
bubpeter is offline   Reply With Quote
Old 01-19-2012, 02:43 PM   #2
Rewards Points: 12,804
Drill and do not have them any closer then about 3" from the bottom of the joist.
Any place you can run along the sides of the joist it's fine to staple.
Old 01-19-2012, 02:47 PM   #3
Excellent, thanks... was just trying to see if I could skip some drilling. Its only 10' to the panel.
Old 01-19-2012, 02:51 PM   #4
What would someone have to do if they decided to do something with that ceiling later on. All the wiring would have to be pulled and redone.
Old 01-19-2012, 04:30 PM   #5
Its actually just my basement utility room with my oil tank and boiler etc. There's already cable TV, thermostats and doorbell wiring and also piping attached under the joists. Was wondering about future home inspections ...
Old 01-19-2012, 05:03 PM   #6
Licensed electrician
Rewards Points: 1,014
Smaller cable can be run under the joist if on running boards. Larger cables can be secured under the joists.
Inside Walls Cable Fishing/Routing tk3000 Building & Construction 9 07-05-2011 09:15 AM
Re-route dryer electric cable Stu27 Electrical 10 09-06-2010 09:21 PM
Effects of electrician tape on cable richard7994 Electrical 4 08-11-2010 09:39 AM
Cable question tommy_vercetti Home Theater 15 09-26-2009 10:10 AM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 03:54 PM
