CABLE For TV In Basement - Electrical - DIY Chatroom Home Improvement Forum
Old 06-18-2007, 08:38 AM   #1
Question
CABLE for TV in basement
Hello All!
I want to run cable into my basement which I am finishing. Luckily, the wall that I want the tv on in the basement is the same wall that the tv cable hookup is on on the first floor family room and the location is almost directly below the tv on the first floor. How do I, or what its the best way to get the cable tv supply into the basement? Do I need to have my cable company do it?
thanks in advance for any help/advice!
DIY4EVER is offline   Reply With Quote
Old 06-18-2007, 08:57 AM   #2
RippySkippy's Avatar
Does your cable company charge for this service? If not, you might have them do it correctly.
Is the existing service in a low voltage box with plenty of space in the stud cavity? You can always split the existing connection in the wall. From the bottom, you would drill up through the sub floor, bottom plate and fish a new cable down in to the basement. Keep in mind that you may also degrade your signal.
RippySkippy is offline   Reply With Quote
Old 06-18-2007, 07:48 PM   #3
joed's Avatar
Rewards Points: 12,002
Don't put a splitter inside the wall where you can't get to it.
The best way is to run a new cable all the way back to where the cable enters the house and split it there.
Old 06-18-2007, 08:38 PM   #4
yummy mummy's Avatar
Rewards Points: 1,016
That is exactly what I did with my TV cable. I ran it from where it comes in all the way to the wall that I want it to go to.
yummy mummy is offline   Reply With Quote
Old 06-19-2007, 07:21 AM   #5
If the OP has the low voltage box, the ones with out a back in it, and chooses to split the cable in the wall, he will have access to it.
There's a lot of details left out of and since we don't know where his cable comes in, and whether he has access to the entrance point we don't know what he's working with. In my old house the cable installers ran the cable around the exterior of the house, drilling holes where ever they wanted a crappy face plate connection in the room. If that's what he's working with, I would rather have an accessible connection in the wall than yet another hole in the exterior of the house.
It all depends on the details which we don't have.
Old 06-19-2007, 07:01 PM   #6
joed's Avatar
Cable installer don't do quality installs. They fast installs.
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 10:09 AM
Sub Basement Walkout - Please Help pgs_28 Building & Construction 11 08-12-2007 10:55 PM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 03:54 PM
Noob question for basement finish electrical dtmbizzle Electrical 16 07-11-2007 08:08 AM
Wet Basement being fixed (pics) harleysilo Remodeling 2 01-23-2007 09:09 AM
