Cable Television - Electrical - DIY Chatroom Home Improvement Forum
Old 01-24-2010, 11:30 AM   #1
Lightbulb
cable television
I have a 32' tv hooked up via a comcast cable box. I brought in a 51' hdtv and set it up the same way the smaller tv was setup. It blew the breaker.I then tried the plugging the coaxial directly to the tv bypassing the box and the coaxial sparked at contact with tv.I tried using video wires instead of coaxial and still blew the breaker.This tv worked fine at my other house.I took every thing that was plugged into that breaker off line and got the same results.I can set up the 32' still with no problems.Does the larger tv require that much more juice or does it possibly have a short in it since transporting it? It was transported in the upright posistion and was stabilized pretty good.Any insight will be appreciated.Also,the tv will power up without the coaxial connected.
ecky1923 is offline   Reply With Quote
Old 01-24-2010, 11:43 AM   #2
Rewards Points: 20
I'm suspecting the T.V. Try hooking it up and plug the T.V. into a different circuit with an extention cord as a test.Have you tried plugging in the T.V. without hooking anything else to it?
daveb1 is offline   Reply With Quote
Old 01-24-2010, 12:17 PM   #3
joed's Avatar
Rewards Points: 11,966
You should not be getting a spark from the cable coax. Something is not right. It could be the cable coax.
Does the TV have a two or three prong plug?
Measure between the coax shield and an electrical ground. There should be zero voltage.
Old 01-24-2010, 12:28 PM   #4
Rewards Points: 20
Posted my first reply before reading your edit.As joed says the coax should not spark.Can you determine if the spark is coming FROM the coax or TO the coax?
Old 01-24-2010, 01:17 PM   #5
coax
spark is at tv, used video wires and plugged in and blew circuit
Old 01-24-2010, 01:20 PM   #6
plug
plug is a 3 prong. the same coax plugs into smaller tv and works fine.
Old 01-24-2010, 02:04 PM   #7
Rewards Points: 6,652
Bad ground at the outlet. Get an electrician, since you are looking at worst things, and definitely at this point, if you screw up the CC equipment, not only are you paying them a monthly bill, but you are looking at least a couple thousand to replace their equipment that you are renting. Not only that, if they find out that there is voltage back feeding out of your house/apt, they can disco and order you to get an electrician, and will not hook you back up until showing proof that the problem is solved.
Old 01-24-2010, 02:12 PM   #8
It is possible that the coax cable at your old house was not "grounded" and therefore there was no problem...
And at your new house the coax is grounded (like it should be) and you are now noticing the problem.
Or could be many other things.
I suppose the thing to do is disconnect the coax, then use a voltmeter and *carefully* see where the voltage is coming from. TV or coax?
Don't touch either with your hands as it could be either. Might want to wear gloves as well.
Billy_Bob is offline   Reply With Quote
Old 01-24-2010, 02:32 PM   #9
Rewards Points: 1,440
Maybe the cable company's equipment has the short.
Disconnect the incoming cable from the cable box.
Disconnect the cable box from the TV but leave boht plugged in and turned on.
Measure voltae beteen the incoming cable plug shell and ground.
Measure voltage between a coax cable stud on the box and ground.
Measure voltage between a coax cable stud behind the TV and ground.
Does the cable box have a 2 or 3 prong plug?
Report the results here.
Old 02-25-2010, 10:09 AM   #10
Did you ever pin down the problem, or find a solution? I just discovered a very similar issue and will post a new thread if this one remains unresolved (rather than hijack it).
reader4 is offline   Reply With Quote
Cable question tommy_vercetti Home Theater 15 09-26-2009 10:10 AM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 03:54 PM
