Cable Splice Kit Instead Of Juction Box? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-20-2008, 06:24 PM   #16
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
Originally Posted by pat72 View Post
Makes lots of sense but why don't they want to approve a product such as the Tyco kit used in mobile homes for every house in the country? If that plastic thingy can be UL listed, I would think that a similar product could be designed, tested and approved for a stud home which would be a great way to avoid the aggravation of having to install a JB in some unsightly spot in order to add 4 ft of lenth to an existing run.
I have installed the services and other install work on the mobile homes and prefab homes which use those splice do dads on romex. But they do remain accessible. Not in J boxes but behind removable panels or in the attic next to the scuttle.
John
jrclen is offline   Reply With Quote
Old 07-21-2008, 03:21 AM   #17
John, this is interesting. You have to keep them accessible even though 334.40(B) says that they can be concealed and fished!?!
Do you go the extra mile to make troubleshooting down the line easier or do you keep them accessible to please the inspector?
pat72 is offline   Reply With Quote
Old 07-21-2008, 08:27 AM   #18
jrclen's Avatar
Rewards Points: 514
I'm not sure we are talking about the same thing. The connectors I'm referring to are flat plastic push together connectors for the three or four conductors of a romex connection. They are used to connect the wiring of the two halves of a double wide or prefab home. But they would pull apart I think during fishing. I wish I could find a link to them or had taken a picture. Most of the homes I have done with these supplied have had them located in the attic and thus would be accessible. The last one was behind a removable metal grill in a bedroom closet. I am not sure if they need to remain accessible per code, just that it works out that way. I don't think the connectors are very suitable for fishing. One would need a large hole for one thing. I am not sure what 334.40 is referring to. I need a picture.
John
Old 07-21-2008, 05:12 PM   #19
Master Electrician
JohnJ0906's Avatar
I think I know what you are talking about. I have seen those things with modular homes, to connect the sections, but they were always, as you said, accessible.
I'm not sure if that is what that article is referring to.
John from Baltimore
One Day at a Time
"Experience is what you get when you were expecting something else"
"The bitterness of low quality lingers long after the sweetness of low cost is forgotten"
JohnJ0906 is offline   Reply With Quote
In-Floor Heating Cable Trouble... sootybuttercup Electrical 24 12-18-2014 08:01 PM
What's the best way to splice 1/0 cable? Randell Tarin Electrical 30 02-01-2008 02:38 PM
Projector Receiver cable TV box bigboyjoel Home Theater 4 12-19-2007 02:23 PM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 02:54 PM
