Cable & Separate Ground Wire In Conduit? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-17-2011, 04:13 PM   #1
Cable & separate ground wire in conduit?
Sorry to start a new thread, but my last one got a little sidetracked.
Would it be acceptable to run a separate grounding wire alongside a 6/2 SEU cable provided they are all within a single conduit? Judging by this section of the NEC, it seems like it would be acceptable, but I'm not 100% sure.
shadetree is offline   Reply With Quote
Old 12-17-2011, 04:45 PM   #2
jproffer's Avatar
Rewards Points: 716
Yes that should be fine as far as the ground goes.
One of the experts can verify or correct me here, but I thought I read somewhere that running grouped cable (romex, SEU, etc) in a conduit was against code because it would be "double conduit" (I guess saying that the outer covering would be one "conduit"
jproffer is offline   Reply With Quote
Old 12-17-2011, 06:44 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
No. you can not run a ground wire outside of the cable, even in conduit and be compliant.
Old 12-17-2011, 08:19 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
I have to say, regardless of legality, running a new SER cable will be MUCH less work, but only a bit less cost, than running a new conduit and pulling your old cable in it.
Price the conduit and ground wire, then price a piece of SER cable, and weigh the cost difference to the work/PIA factor difference. I'd go SER every time.
The Following 3 Users Say Thank You to Speedy Petey For This Useful Post:
frenchelectrican (12-18-2011), Ravenworks (04-25-2012), SD515 (12-18-2011)
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 09:01 AM
Ground Location and Wire Size LHB_Texas Electrical 25 05-27-2011 09:38 AM
240v conduit with different gauge wires... Biospot Electrical 7 12-14-2010 07:07 PM
Adding ground in old home ChaosTheory Electrical 6 06-16-2010 04:02 PM
Sub panel grounding sluggermike Electrical 27 11-11-2007 01:23 AM
