Old 08-20-2008, 10:10 PM   #46
Send a message via AIM to theatretch85
Cable issue or wiring issue?
Originally Posted by bob22 View Post
theatretch85:
If all breakers are off, I would think that there should not be any voltage reading between any of the outlet slots assuming no wiring issues or backfeeding through neutral. Where is this thinking wrong?
Thanks,
Bob22
Right, I was thinking when the power is on. It would probably be a good idea to check that to make sure the ground really is a ground at zero potential along with the neutral. If there is power between the neutral (wide blade on outlet) and ground, then theres a problem in the electrical system.
Try checking the voltage between the neutral and the coax and see what you get.
theatretch85 is offline   Reply With Quote
Old 08-20-2008, 10:33 PM   #47
Electrician's Helper
Pudge565's Avatar
Send a message via AIM to Pudge565
Im thinking bootleg ground with open neutral.
Pudge565 is offline   Reply With Quote
Old 08-21-2008, 09:00 AM   #48
Licensed Electrician
jrclen's Avatar
It is entirely possible the coax is shorted to another electric service and the electricity is using the OP's grounding system as a path back to where ever it is coming from.
Now the OP threw in the refrigerator/sink problem. I'd like to know the voltage reading between the coax and the sink. Do we have an energized plumbing system also? This is getting more interesting every day.
John
jrclen is offline   Reply With Quote
Old 08-21-2008, 09:10 PM   #49
TADA!!!! Thanks in part to you fine gentlemen the problem has been solved. Any bets on what it was?
If you said open ground then you've just won my eternal respect!
Wow, four years living with that problem and just now getting it fixed. Lucky no one got hurt.
Duchey is offline   Reply With Quote
Old 08-21-2008, 09:30 PM   #50
Electrician
SD515's Avatar
Awesome Duchey !! I'm glad you are able to live through it...seriously !
Open ground, eh?? Where??
My money was on open/loose neutral. Do I win at least some of the pot??
Old 08-22-2008, 11:53 AM   #51
jrclen's Avatar
I'd like to know more about this. Open ground? Nothing else wrong? That doesn't sound quite right. Are you sure someone didn't say open grounded conductor? That would be a neutral and make sense.
I am happy for you that the problem has been fixed no matter what it was.
John
Old 08-23-2008, 05:22 PM   #52
I'm with ya on that one. I don't know if I buy the story from the LL or not. I'm betting it was something far more serious and he's just not telling me.
Old 08-24-2008, 10:55 AM   #53
Electrician
SD515's Avatar
Yeah Duchey, it sounds like you got a generic answer from your LL. I agree with what JR said, and would like to know what the actual fix was. It help us in our future diagnosis.
Old 09-09-2008, 10:57 AM   #54
Wow, took me a while to digg this one back up.
I cornered the LL a few days ago and finally got him to give me the whole story. Apparently the ground had been wired hot the whole time. He said that the wires had gotten "mixed up" at the main box back when the place was re-wired.
Darn lucky the place never burnt down.
Old 12-14-2008, 12:00 PM   #55
Can I ask...what was the outcome with the cable company and the wiring? I am having a very similar issue, however we are getting 120V intermittently off the cable line when it is not connected to the house. When it is hooked up to the house then we get intermittent readings of 120V through the cable jack in our living room. I also have recently been through 2 cable boxes and fried a TV and the cable technician was shocked 3 times on his trip to troubleshoot our cable problems. He claimed that it was the television that had the problem. However, I'm not sure how that is possible considering he first was shocked outside the house while changing out the coax. Any more information would be helpful since the next technician is coming this Tuesday and I'm not entirely confident they will be able to assess and fix the problem.
Thanks!!
capuchin is offline   Reply With Quote
Old 12-14-2008, 12:54 PM   #56
My License Ain't 4 Sale..
Thanks!!
Maybe an Admin will make this a thread another thread?
If you are reading 120 V on the coax to ground, before it is attached to your house, then there is a line cross somewhere and the cable company's ground has failed upstream of your house. That's what the next technician needs to be told.
Old 12-14-2008, 02:25 PM   #57
What would likely have happened if you had grounded the offending cable shield and left it (bonded) that way.
Often I have suggested that amplifiers, DVD players, etc. be bonded to each other and ground. This is done by being daisy chaining to a wire running among them with appropriate screw connections penetrating the various chassis and with the far end of the wire connected to a known ground.
Old 12-15-2008, 02:34 PM   #58
jrclen's Avatar
I agree with Inphase. There is more to this than meets the eye. A ground, or the cable outer jacket should have no voltage potential. None. We could eliminate the ground completely and never notice the difference in a properly operating system. Electricity always wants to return to it's source, not to the earth.
John
Wiring my garage with direct burial cable? Earl Smith Electrical 3 08-10-2008 07:28 PM
1930s armored cable wiring Lisa_90 Electrical 9 08-01-2008 10:24 AM
wiring Samsung MH080FXCA4A/MH052FNCA m_driver HVAC 1 07-06-2008 10:44 PM
Century Home Wiring Issue fradam1976 Electrical 14 05-07-2008 02:53 AM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 03:54 PM
