Cable Going Outside For Entrance Flood Light - Electrical - DIY Chatroom Home Improvement Forum
Old 10-31-2008, 05:35 PM   #1
Rewards Points: 1,062
Question
cable going outside for entrance flood light
does the cable going outside for an entrance flood light have to be UF ? the light is motion sensored and is affixed directly on the brick wall above the door. the cable will run straight through the brick wall and into the light receptacle, i.e. no conduit running alongside the wall. also, does the cable have to go through PVC conduit or can it just go through the hole in the brick ?
Old 10-31-2008, 06:37 PM   #2
dSilanskas's Avatar
If your going right through the brick to the other side into a box. Yes you have to protect the romex by some sort of sleeve. PVC is not a bad idea or carflex. It does not have to be UF Romex unless your running the wire along the outside of the house.
dSilanskas is offline   Reply With Quote
Old 10-31-2008, 07:56 PM   #3
HUH?
Romex is run thru brick all the time to every outside light in every brick house I've ever seen.
Inside the brick = inside the structure.
220/221 is offline   Reply With Quote
Old 11-01-2008, 01:06 AM   #4
dSilanskas's Avatar
Originally Posted by 220/221 View Post
HUH?
Yes it is so whats your question?
Old 11-01-2008, 12:06 PM   #5
Rewards Points: 58
HUH?
Totally agree. It's done all the time and is not a code violation. Of course if you feel better with a sleeve. Have at it.
Old 11-01-2008, 04:12 PM   #6
dSilanskas's Avatar
HUH?
If you re read what I wrote I said that you only need to use UF romex if you are going along the outside of a building
Old 11-01-2008, 05:04 PM   #7
Old 11-01-2008, 05:30 PM   #8
dSilanskas's Avatar
220/221 if your going to run romex through brick or stone why woudn't you protect it with pvc or carflex? Silly silly monkey
Old 11-01-2008, 05:34 PM   #9
Electrician
Because you dont need to. Silly silly monkey!
chris75 is offline   Reply With Quote
Old 11-01-2008, 05:43 PM   #10
dSilanskas's Avatar
Sure you dont have too but why not? For better protecton? Well unless that is the way you guys like to do things The code is bare minimal why not go above the code and make it even more safe
Old 11-01-2008, 06:17 PM   #11
electrician
Why not? Because it's idiotic and a waste of time and your customers money, that's why.
Silk is offline   Reply With Quote
Old 11-01-2008, 07:10 PM   #12
dSilanskas's Avatar
Haha well perhaps your idiotic to think that it really takes that much longer to stick a pipe through a wall So its at the most 10" of 1/2 pipe or whatever you use and about two minutes But oh yes that is a lot of time and money
Old 11-01-2008, 08:31 PM   #13
electrician
Well let me think about that................. No, it's still you.
Old 11-01-2008, 08:50 PM   #14
Rewards Points: 2,350
Well usually, in a new construction situation, the wire is stubbed out with a box attached. Then the brick mason will brick around it, and the wire is never in contact with the brick. In a remodel or old work setup, I'd chisel a brick out and install a masonry box, and the wire still never touches the brick. It would be a waste of time to install a pipe, only to turn around and remove it when you take the brick out anyway.
Old 11-01-2008, 09:05 PM   #15
dSilanskas's Avatar
haha well to each his own you do things your way and i will do things the better way
Question with wiring up a flood light. SuperAkuma Electrical 6 09-20-2008 11:58 AM
Motion Sensor to Flood Light Unit TTran Electrical 3 05-31-2008 10:50 AM
Outside conduit to flood light moneymgmt Electrical 5 02-06-2008 09:08 AM
Electric receptacle in lamp post and flood light not working th31 Electrical 7 12-13-2007 08:46 AM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 03:54 PM
