Cable Direction - Electrical - DIY Chatroom Home Improvement Forum
Old 07-16-2012, 09:29 PM   #1
Rewards Points: 1,062
Is there a diagnostic tool that lets you determine the charge-load direction of a cable, i.e. on which side of it is the charge (closer to the panel) and which side is load (closer to outlets)?
Without cutting the cable, of course. Can a clamp meter tell you that?
Thanks.
Old 07-17-2012, 02:05 AM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,110
Nope....sorry....no way to tell electrically....
But, if the cable goes to a box....disconnect the wires....one set will have power, the other none....
ddawg16 is online now   Reply With Quote
Old 07-17-2012, 02:14 AM   #3
i had to set a JB and branch off a circuit and it was in the middle of a cable and it did matter where i cut the cable cause the space was tight ... to make a long story short, i needed to cut on the side closer to the panel and stick that end in the JB. the chances were 50/50. it was a crapchute but the coin fell on the right side and everything works
sound out of cable box amakarevic Home Theater 11 05-18-2012 11:26 AM
Need help sizing Generator cable dgajr Electrical 2 07-20-2010 01:07 AM
Evaluating a kinked cable dave11 Electrical 5 05-09-2010 11:20 AM
Coaxial Cable Junction Box/Split apriest Electrical 19 07-23-2009 09:33 PM
Underground service entrance cable requirements. kgt55 Electrical 9 06-22-2009 07:55 AM
