Cable Clamps - Electrical - DIY Chatroom Home Improvement Forum
Old 11-06-2012, 05:41 PM   #1
Rewards Points: 207
cable clamps
Installed an octagon box that did not have any cable clamps for nm cable on it for a bathroom light. To install the cable clamp should the ring be on the inside or outside of the box? Drywall finish. Thanks.
gt1935 is offline   Reply With Quote
Old 11-06-2012, 05:43 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
What ring? The lock nut should be on the inside of the box.
Old 11-06-2012, 05:47 PM   #3
You install the connector from the outside, you then tighten the ring around the threaded part of the connector on the inside of the box.
Gensetter is offline   Reply With Quote
Cable Fastening & Cable Bundles ctlu008 Electrical 13 01-15-2012 06:43 PM
Aerial Cable to Garage & Adding Sub Panel CDW59 Electrical 5 12-09-2011 06:43 AM
Need help sizing Generator cable dgajr Electrical 2 07-20-2010 12:07 AM
Evaluating a kinked cable dave11 Electrical 5 05-09-2010 10:20 AM
Running Sky+ cable bookersbeauty Electrical 1 04-09-2009 07:12 PM
