Cable Clamp On Meter Main To House? - Electrical - DIY Chatroom Home Improvement Forum
Poll: How should you mount the Clamp on Meter Main to Inside House?
Poll Options
Old 12-18-2014, 09:15 PM   #1
Rewards Points: 392
Cable Clamp on Meter Main to House?
OK,
I'm going to mount a new meter main on the outside of the house of the attached garage mounted to the T-111 coated 2x4 stud wall. When mounting the cable clamp shown below, do you want the screws on the inside of the panel or on the outside (buried in line with the T-111 siding)? If they are on the outside, that likely means a bigger hole cut in the T-111.. Do you even need to use this clamp, or would a plastic ring be better or can you just use a smaller wood hole to protect the sheath of the cable and basically use nothing in the panel to secure the cable? Please give me your comments..
I'm doing a 200A service with 4/0-4/0-4/0-2/0 SER Cable.
Considering 2" cable clamp.
Thanks,
Jeff
zootjeff is offline   Reply With Quote
My Cable TV Project (Advice Needed) 95PGTTech Electrical 19 08-30-2014 03:59 PM
meter & main service panel upgrade from 100amp to 200amp CapeCod153 Electrical 2 03-26-2013 07:23 AM
building new house 200' from meter n175h Electrical 14 03-18-2013 07:56 AM
Running pex from the meter to the house, but what about above ground? chayce Plumbing 4 11-09-2010 06:36 AM
New clamp meter question Chevyman30571 Electrical 18 02-21-2010 11:35 PM
