Cable - Electrical - DIY Chatroom Home Improvement Forum
Old 09-27-2011, 09:37 AM   #1
Cable
When turning on a light switch or the dishwasher the lower channels on my tv get real staticky, can turn off and they clear up, what could be the problem?
magickitchen is offline   Reply With Quote
Old 09-27-2011, 10:08 AM   #2
Rewards Points: 6,652
Noise feeding into the catv system. Call your cable company to put in a ticket. Do not tell them when you call that it is elictric caused. Tell them that when watching tv, all of your channels are really snowy, and that you would like to schedule a technician. Then when the tech gets there, walk through with them, the exact steps that is causing it. Now what you can do, is go out where the catv enters the residence, and make sure the ground wire from the ground block that your line enters, is grounded to the ground rod for your electric meter, not attached to the meter housing.
Then go through and check all connections. Usually stuff like static is caused by a ground loop, no ground on the home catv plant, or bad quality coax, or nicked outer sheathing on the coax jacket.
The Following User Says Thank You to gregzoll For This Useful Post:
magickitchen (09-27-2011)
Old 09-29-2011, 08:36 AM   #3
Cable
Now the technician with the cable company came out and wasn't able to pinpoint the problem with turning on the dishwasher or light switch interfering with the television picture. Now what can I do?
Old 09-29-2011, 08:50 AM   #4
Go back and do like I stated before, by checking the grounds. Call and get another technician out there and make sure they cut off the current coax ends, and crimp on new ones, fix the ground at the ground block. Keep chewing up the food chain, until you can get someone that will come out there and fix it. The best solution if you own, is pulling all new coax and trying to make sure that you have the inside plant set up correctly.
If you want to pull new coax, there is no problem doing it, but if you want to put on the ends, the newer type compression can take some practice to get them correct. Who is the provider, and what is your location?
Old 09-29-2011, 09:34 AM   #5
I=E/R
a7ecorsair's Avatar
You need to provide some more detail.
Do you have a grounded electrical system - three prong receptacles?
Where is the cable box - how far - in relation to the TV?
You should have some type of cable junction box outside the house, do you?
When did this problem start occurring?
Typically, with a cable box, you set the TV to a specific channel and then use the cable box to change channels. Is this how you use your system?
a7ecorsair is offline   Reply With Quote
Old 09-30-2011, 10:50 AM   #6
the cable is run underground to house in same trench as electric, electric is in conduit, electric is grounded. have a dvr in entertainment center just above the tv, been going on around a month. When i turn oo a light switch or the dishwasher is running there is alot of static in lower channels. Cable guys still looking at problem but have no answer.
Old 09-30-2011, 11:20 AM   #7
Mark Potter's Avatar
Rewards Points: 150
This should be cable issue is the cable box new? And or tv old? Is all your plugs plugged Into one outlet and or power strip?
Mark Potter is online now   Reply With Quote
Old 09-30-2011, 11:27 AM   #8
I=E/R
a7ecorsair's Avatar
Do you have a cable box or do you have the incoming cable connected directly to your TV?
Old 09-30-2011, 11:35 AM   #9
cable is run thru dvr, tv less than one year, dch dvr failry new
Old 09-30-2011, 12:13 PM   #10
Rewards Points: 150
Could be cable line any bad storms and or lot of rain?
How are the digital cables from dvr to to high quality thick cables? Name brand?
Old 09-30-2011, 01:16 PM   #11
I am in a small town,locally owned company, technician just left, has ran a line from the pole to the house and said the problem was in the house. I have already had an electrician check it out to find nothing wrong.
Old 09-30-2011, 01:30 PM   #12
Rewards Points: 150
Lol that's because problem was the cable line and wont admit it although fix it and blame it on you in other words. Gggrrr! lol
The Following User Says Thank You to Mark Potter For This Useful Post:
magickitchen (09-30-2011)
Old 09-30-2011, 03:27 PM   #13
I=E/R
a7ecorsair's Avatar
Let's step back and review your setup.
You have a DVR
Your cable connects to this DVR.
Your TV is connected to this DVR.
I need to know how the TV is connected to the DVR and there are several choices:
HDMI
Component
S-Video
Coax
Let me know which one you use.
Next, do you have an antenna that is connected to your TV or is the only connection the one from the DVR?
I'll wait for a reply to these questions.
Old 09-30-2011, 05:18 PM   #14
dmxtothemax's Avatar
Rewards Points: 5,188
Sounds like poor signal to noise ratio,
Or poorly instaled ditrubution system.
When turning on some lights,
some sparking happens in switch,
Same with any load.
How much sparking depends on the nature of the load
and the condition/quality of the switch.
But if the distro system is done correctily
then it should not get in.
A poor signal to noise ratio (weak reception) can compound this.
You need an experienced engineer to look at your distro system.
dmxtothemax is online now   Reply With Quote
Old 09-30-2011, 08:50 PM   #15
I=E/R
a7ecorsair's Avatar
With digital TV there is no frequency spectrum as there was with over the air analog TV. With digital TV you either have a picture or you don't. There is no snow.
So, my questions are for understanding how the OP is selecting the lower channels.
Inside Walls Cable Fishing/Routing tk3000 Building & Construction 9 07-05-2011 08:15 AM
Re-route dryer electric cable Stu27 Electrical 10 09-06-2010 08:21 PM
Effects of electrician tape on cable richard7994 Electrical 4 08-11-2010 08:39 AM
Cable question tommy_vercetti Home Theater 15 09-26-2009 09:10 AM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 02:54 PM
