Cabinet Screws Showing 30 Volts AC - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-16-2014, 07:35 PM   #16
Rewards Points: 3,256
High impedance and/or inexpensive meters can pick up all sorts of voltages that are of no issue. You never mentioned what happened to your son when he was installing the screw. Shock? Breaker tripped?
zappa is offline   Reply With Quote
Old 06-16-2014, 07:42 PM   #17
jkk
Rewards Points: 233
Slight tingle. Thankfully.
jkk is offline   Reply With Quote
The Following User Says Thank You to jkk For This Useful Post:
zappa (06-16-2014)
Old 06-16-2014, 07:49 PM   #18
Well that's good to hear. Did you happen to measure between the screw and ground before removing it?
Old 06-16-2014, 08:39 PM   #19
jkk
Rewards Points: 233
No, he removed it before calling me.
Old 06-16-2014, 09:00 PM   #20
I wouldn't be comfortable knowing that a damaged cable might be inside the wall.
Old 06-16-2014, 09:46 PM   #21
Rewards Points: 3,396
Same here.
Just wondering, you mentioned sheetrock?
Not knowing, but is there any possibility of the sheetrock being over metal lath and plaster, or just the metal lath?
Just throwing it out there.
ritelec is offline   Reply With Quote
Old 06-17-2014, 01:42 AM   #22
dmxtothemax's Avatar
Rewards Points: 5,106
There are several reasons why you could measure a voltage on these screws
But we are only guessing as he has removed. The screws
But if there is a chance of now damaged wires being in the wall
Then it would be wise to open up the wall and check it out !
dmxtothemax is offline   Reply With Quote
Old 06-17-2014, 02:29 AM   #23
JOATMON
ddawg16's Avatar
Rewards Points: 1,162
I was about to suggest that it was the OP's charismatic aurora causing the voltage....
To be honest...most people wouldn't admit to making a mistake....it's a good man who does.
With that said....any time I get a voltage like that....I touch it with my fingers. It's low enough to not do any damage (to me) if is in fact a real voltage. 99.9999% of the time, touching it injects enough resistance to ground to make it go away.
And there are times where you just can't beat a good ol' Simpson 260 VOM
Old 06-17-2014, 07:42 AM   #24
Rewards Points: 338
Yeah, but who wants to lug around that big azz analog meter?
petey_c is offline   Reply With Quote
Old 06-17-2014, 09:08 AM   #25
A low impedance feature on a digital is handy.
Old 06-17-2014, 09:40 AM   #26
JOATMON
ddawg16's Avatar
But it's a classic....and shows things hard to see with a digital...and doesn't need batteries
Old 06-17-2014, 10:24 AM   #27
Rewards Points: 338
I'm just a little biased. I used to have to repair 260's in the Navy. I liked them a lot. Test equipment has come a long way since the 80's. Spectrum anaylers that would give you a hernia then, can be lifted with ease now, but I digress...
Loose stainless steel deck screws drtbk4ever Building & Construction 17 06-19-2012 10:26 AM
Need help! Cabinet install gone slightly wrong eemichael83 Carpentry 14 10-26-2010 04:46 PM
Metal roof energized (showing 29 volts to ground) bluefitness Electrical 5 05-07-2010 11:33 PM
Does Home AC ever read 0 volts? step.gary Electrical 3 07-01-2006 04:57 PM
