Cabinet Screws Showing 30 Volts AC - Electrical - DIY Chatroom Home Improvement Forum
Old 06-16-2014, 10:01 AM   #1
jkk
Rewards Points: 233
Cabinet screws showing 30 Volts AC
We were changing a receptacle used for washing machine. Turns out this line is a 12/3 line run as a shared neutral for the refrigerator. That explains why the neutral was showing 120 VAC to ground, with the breaker off.
Last month my son was hanging a cabinet just above this receptacle. He was probably kneeling on, or had his arm resting on the dryer while driving in the 3" cabinet screws. I figured he hit a wire so we'd have to take the cabinet down, remove drywall and see what happened.
So, with this 120VAC neutral to ground, before I realized it was a shared neutral, I decided to connect a voltmeter to the neutral (disconnected from the receptacle and thus disconnected from the panel, I think) and this screw. It showed 30VAC. The other 2 cabinet screws, in 2 different studs, show about 20 VAC.
How could this be? It appears the screws are connected to earth ground ... ?
jkk is offline   Reply With Quote
Old 06-16-2014, 10:37 AM   #2
Master Electrician
Rewards Points: 3,918
It appears to me the pierced a cable.
brric is online now   Reply With Quote
Old 06-16-2014, 10:49 AM   #3
jkk
Rewards Points: 233
Probably, but getting 3 screws, in 3 different wall studs, to show a path to ground from 1 screw that had maybe pierced but thdayen withdrawn and relocated ... seems very unlikely. I'll see later today when we remove drywall.
Old 06-16-2014, 10:55 AM   #4
Master Electrician
Have you turned both breakers of the MWBC off?
Old 06-16-2014, 11:29 AM   #5
jkk
Rewards Points: 233
Originally we only turned off one, until we discovered that shared neutral. However, I still need to learn why the screws-into-studs have some path to ground.
Btw, what is MWBC?
Old 06-16-2014, 11:33 AM   #6
Master Electrician
Btw, what is MWBC?
Multi-wire Branch Circuit. 2 hots, one shared neutral, one grounding conductor.
The Following User Says Thank You to brric For This Useful Post:
plummen (06-16-2014)
Old 06-16-2014, 12:14 PM   #7
Rewards Points: 3,396
the screws don't, the wood does
google " pyrophoric carbonization "
ritelec is offline   Reply With Quote
Old 06-16-2014, 12:21 PM   #8
jkk
Rewards Points: 233
Well, the screws have to, albeit through the wood. Pyrophoric carbonizing does not seem to deal with electrical conductivity, just combustibility.
Old 06-16-2014, 02:26 PM   #9
Just combustibility? You missed the point. The combustibility was do to conductivity.
It's the wood, not the screw. This phenomenon is the result of it's electrically conductive nature.
The screws and nails help it along, but it's in the wood.
The screw gave you a metal reference for measurement. It's not the screw.
The screw is a screw.
Old 06-16-2014, 02:49 PM   #10
I must say though, there should be no reason why you are reading 30v through a screw.
I don't think the wood would be that conductive.
Something else is going on which you may or may not find when you start the rip out.
Who know's, there may be a long nail plate across those studs that's hot.
Old 06-16-2014, 02:54 PM   #11
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
My first question would be what are you metering between? Ground and the screws? For all you know the voltage you are reading could be on the ground and not the cabinet screws.
Old 06-16-2014, 05:35 PM   #12
Rewards Points: 407
Before you start ripping drywall out.....use a different meter and see if you get the same reading...just saying.
DanS26 is offline   Reply With Quote
Old 06-16-2014, 05:41 PM   #13
jkk
Rewards Points: 233
The measurements above were from the screw to a disconnected neutral that I think was coming from the fridge. That neutral measured 123 VAC to ground.
Now that I'm home, I measured other cabinet screws, to hot (black), in other parts of the kitchen, and I get anywhere from 2 to 15 VAC from screw to hot (black). In some studs, I have 2 screws ( top of cabinet and base of cabinet) - and I get 8.5 VAC at the base screw and 6.0 VAC at the top screw ( further from receptacle, if that matters but I don't see how why), measuring to hot (black). This happens on 2 different studs.
I'd like to see if other people get similar results from their kitchen cabinet screws to hot on receptacles.
The largest reading so far is 15 VAC from screw to hot.
Old 06-16-2014, 06:13 PM   #14
jkk
Rewards Points: 233
Good suggestion!! Another meter shows 0.5 volts from various screws to hot, independent of where the screws are. The first meter showed 135 VAC across hot and neutral on a receptacle that has 1 125 AC home and 5Vdc USB ports. The 2nd meter reads 125VAC across those same points.
Not sure how I would get consistent bad readings from that 1st meter - how the readings would vary with distance from the hot wire ... Must be very sensitive to resistance changes in the wood ...
Old 06-16-2014, 06:34 PM   #15
jkk
Rewards Points: 233
Ok, the embarrassment factor gets worse. The 9V battery, on the meter giving bad readings, was really a 5.7V battery. Worse yet, the low battery symbol was on but I didn't see it. Wow. Good thing I didn't tell people here I've got a master's degree in electrical engineering from a well known engineering university.
Sorry to waste your time.
The Following User Says Thank You to jkk For This Useful Post:
oh'mike (06-17-2014)
Loose stainless steel deck screws drtbk4ever Building & Construction 17 06-19-2012 09:26 AM
Need help! Cabinet install gone slightly wrong eemichael83 Carpentry 14 10-26-2010 03:46 PM
Metal roof energized (showing 29 volts to ground) bluefitness Electrical 5 05-07-2010 10:33 PM
Does Home AC ever read 0 volts? step.gary Electrical 3 07-01-2006 03:57 PM
