A/C Zip Line Question - Electrical - DIY Chatroom Home Improvement Forum
Old 06-09-2011, 05:40 PM   #1
A/C zip line question
Regarding the ac line in a new ceiling lamp... The lamp came with a clear ac line. One side of the line is completely clear, the other side has numbers printed on it for the entire length. Is there a traditional way of connecting the line to the wires coming from the lamp sockets. What I mean is, should the side with the numbers printed on it, be connected to the white or black wires from the sockets, or should I just note which way I connect them. Of course the lamp would work either way, but for maximum safety, I would think that it would be best to have the hot wire switched, and go to the center of the socket. That would prevent an unpleasant surprise in the event of one hand being on the grounded lamp frame, and the fingers of the other hand slipping on to the metal part of dead light bulb being removed while the power is on
JeffL is offline   Reply With Quote
Old 06-09-2011, 05:44 PM   #2
Licensed electrician
Rewards Points: 1,634
The side identified with a raised ridge or printing is the neutral. It connects to the socket shell of the fixture and the white neutral from the ceiling.
Old 06-09-2011, 06:52 PM   #3
Thanks Jim, I had a 50/50 chance and I did it right
Leaking cast iron drain pipes + roots in 4" main line aminus21 Plumbing 5 09-25-2010 10:21 AM
New ICe maker line causes ice to taste like rubber speedster1 Plumbing 5 06-27-2010 08:09 AM
GFCI question: can line and load wires be run inside the same conduit? thegonagle Electrical 32 04-16-2009 06:07 PM
electric line and gas line couch potatoe Electrical 17 09-30-2008 10:43 PM
Question about protecting CSST gas line Racer Plumbing 9 01-10-2007 03:19 PM
