Old 08-19-2012, 06:48 PM   #1
A/C surge vs running amps
I am thinking of installing a 15000 btu window unit in a garage but wonder if there is enough cushion to run some power tools. The unit states a 10.8 SEER and amp of 12.0. It will be on a 15 amp (115vb) circuit.
Does the label amp of 12.0 mean surge amps? Or is the stated number the surge number and while running it is more like ~half that?
puttster
puttster is offline   Reply With Quote
Old 08-19-2012, 06:54 PM   #2
Licensed Electrician
k_buz's Avatar
That is the load it runs at.
Location...Location...Location
Old 08-19-2012, 07:06 PM   #3
JOATMON
ddawg16's Avatar
Like K-buz says....that is your running amps...startup will be much more than that....
Might be time to upgrade the electrical to the garage......
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
Old 08-20-2012, 02:51 AM   #4
Semi-Pro Electro-Geek
12A seems high for a 15k BTU unit. I just put a 16k BTU unit in my friend's garage and it runs about 8A I think. Does your unit also have heat built in? If so, that current rating is probably while heating, not cooling.
mpoulton is offline   Reply With Quote
Old 08-20-2012, 05:39 AM   #5
Electrical Contractor
kbsparky's Avatar
Starting amps can be as much as 6 times your running amps.
You're at the limit with a 12 amp load on a 15 circuit ....
-KB
Old 08-20-2012, 10:09 AM   #6
I would love that. How do you measure the amps? I have a multimeter but don't know where to touch with it. Maybe yours was a 220v, this is a 110.
The 15k is a Frigidaire, A/C only. Next one down would be a 12k LG, said to pull 10.2 amps. But I just don't think it will cool the garage.
Old 08-20-2012, 10:54 AM   #7
JOATMON
ddawg16's Avatar
You will need a clamp on amp probe....
There are two flavors....one is an attachment to your typical multimeter...the other is a all in one device....
Here is a Youtube video of what it looks like and how to use it..
http://www.youtube.com/watch?v=z-KfZvbjyBY
Handy thing to have around....and does not care what the voltage is....you don't need a high dollar unit....
My
and
Old 08-20-2012, 01:55 PM   #8
That's the difference. This was a 240V unit. 12A is probably right, then. I did not measure the current, just read the specs in the manual. You would need a clamp-on ammeter to measure it.
Whole house surge protector - no extra breakers quantumspores Electrical 31 07-15-2012 11:48 PM
Surge protection, HVAC whelmed HVAC 10 06-15-2012 10:13 PM
power surge with 120v relay astetson Electrical 8 01-16-2012 11:46 PM
running electric from house Tradesman14 Electrical 3 01-14-2010 12:16 PM
Amps on only ground? - Danger? jamiedolan Electrical 6 09-21-2008 05:55 PM
