Old 01-07-2013, 09:08 AM   #1
a/c humming
my a/c outside is making a humming noise and I do not have it turned on in my house?
avabean is offline   Reply With Quote
Old 01-07-2013, 09:36 AM   #2
Electrical Contractor
rrolleston's Avatar
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
a/c humming
Did you also try turning off your ac disconnect outside?
Please ask me about my special discount for people that shut up and stay out of my way! With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 01-07-2013, 09:38 AM   #3
a/c humming
Can be a bad contactor.
Old 01-07-2013, 09:42 AM   #4
I'm Your Huckleberry
a/c humming
If you mean the outside condenser is humming although you don't have the thermostat set on call for cool (when was the last time you did have it on cool?) than it could be a combination stuck contactor (allowing power to get to the capacitor) and/or (if a single leg contactor and one leg of 120 volts is constant) simply a bad capacitor.
What kind of condenser is it? Is it a heat pump? Does it work when you turn it on?
Thanks.
Doc Holliday is offline   Reply With Quote
Old 01-07-2013, 10:06 AM   #5
a/c humming
"Heat pumps" use the outside unit for heating. Is it a heat pump?
And they are making these very efficient lately. If it is just humming but the fan is not going, that could be a normal "minimal heat needed" operating mode. Write down the model numbers and call the manufacturer or look at their web site for an owner's manual - which should explain various modes of operation.
Billy_Bob is offline   Reply With Quote
Old 01-07-2013, 06:01 PM   #6
a/c humming
Could be a noisy power transformer used for control circuits !
dmxtothemax is offline   Reply With Quote
Old 01-07-2013, 09:14 PM   #7
a/c humming
If it's a heat pump, and it has one of the old mechanical thermostats, it's normal that sometimes these thermostats apply power to the reversing valve even though no heat or cooling is being called for.
fa_f3_20 is offline   Reply With Quote
Water Pipes Humming Smoke Plumbing 18 02-26-2013 07:24 PM
jet spa tub power is off but still humming sound Ruben Lewis Plumbing 0 01-18-2012 08:48 PM
humming water pipes noelcon Plumbing 0 09-04-2010 12:43 PM
Terrible humming in pipes purplepirate Plumbing 17 07-15-2010 12:09 PM
Trane 1100 XE- Outside unit making humming noise Momof2 HVAC 0 09-03-2009 12:25 PM
