A/c Fuses? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-22-2012, 07:07 PM   #16
Ok, there seems to be some confusion so let me clear it up. I have central heating/air. The unit I was referring to is my a/c unit. And, yes, it says the unit is a Puron by Carrier - I read it straight from the unit. The popping noise came with a spark only at the thermostat in the house. It happened when I was wiring on the new Thermostat. No, the breaker was not on at the time of the pop. I will try to post some pics.
twenta is offline   Reply With Quote
Old 04-22-2012, 07:09 PM   #17
Sparky
Rewards Points: 510
the fuse will be in the air handler inside, not the outside condensor
Techy is offline   Reply With Quote
Old 04-22-2012, 07:12 PM   #18
Ok, so I just need to know where to locate the inside interior air handler. Thanks! Please remember that I am not an idiot. But I don't have any experience with this! Lol
Old 04-22-2012, 07:19 PM   #19
Electrical Contractor
kbsparky's Avatar
There may be a small fuse inside of the air handler unit, and/or you blew out the control transformer.
Many of the newer units have control transformers that burn up very easily, and it may have to be replaced.
You may have to bite the bullet on this one and call in a professional service tech to solve your dilemma.
-KB
Old 04-22-2012, 07:19 PM   #20
Rewards Points: 150
Originally Posted by Jeeps View Post
Being a Carrier unit I believe Code 5 is right on. Look for an automotive 3amp or so plug in type fuse on the control board that will be located in the air handler inside of the house.. They do not "pop" and make a noise so much.
bump..............
Jeeps is offline   Reply With Quote
Old 04-22-2012, 07:25 PM   #21
Ok Code 5, you are telling me what is the closest to sounding right - and of course all of you that agreed. So, I just need to know where to locate this interior air handler!
Old 04-22-2012, 07:32 PM   #22
Sparky
Rewards Points: 510
could be in the attic, a closet, utility room.
where do you change the filter, that is usually fairly close to the unit
Old 04-22-2012, 07:32 PM   #23
I'm Your Huckleberry
Rewards Points: 2,270
Is this a gas furnace or an electric air handler? Air handlers don't have fuses as they don't utilize control boards but sequencers. Gas furnaces have control boards due to the safety features used.
See the purple 3 amp fuse on the left? It'll be just like that, on the control board in the furnace.
Thanks.
Doc Holliday is offline   Reply With Quote
The Following User Says Thank You to Doc Holliday For This Useful Post:
Jeeps (04-22-2012)
Old 04-22-2012, 07:33 PM   #24
Rewards Points: 150
It is either in the basement, attic space, crawlspace or interior closet or out in the garage. A large metal box that may be standing vertical or horizonal with copper tubing running in to it, one tubing will have black rubber foam looking stuff on it called Armaflex. . .
Old 04-22-2012, 07:51 PM   #25
Ok, it must be in the attic, cuz I can't find it anywhere else! However, before I get up there - since it is over 100 degrees today - let me ask this: if this is the problem, is there a different handler for each unit, because my upstairs a/c still works!
Old 04-22-2012, 08:03 PM   #26
Yes, two individual systems. Turn on the upstairs system so you know which one is which as it'll be running and then work on the other one.
Thanks.
Old 04-22-2012, 08:04 PM   #27
Rewards Points: 150
The upstairs floor unit will probaly would be in the attic. IS this a two story, split level, story and a half ? There is another unit somewhere I would think.
Old 04-22-2012, 09:24 PM   #28
Jeeps - it is a 2-story. Doc - thanks, I am letting it cool down a bit since I started to go up and couldn't breath! Lol. Thanks for everyone's help! I will post again after my trip to the attic!
Old 04-22-2012, 10:38 PM   #29
Electrician
Rewards Points: 760
You said you had central heat, did you check in the furnace. The AC is tied into the furnace since it uses the fan to move the cold air.
darren is offline   Reply With Quote
Old 04-22-2012, 10:42 PM   #30
You're correct, they did name a system Puron.
Thanks.
Heat pump wiring and fuses icandoitmyself1 HVAC 13 06-01-2014 05:15 AM
Are fuses still used in new construction? SilveradoGuy Electrical 6 01-17-2012 06:23 PM
Replacing 240V fuses for dryer Mark77 Electrical 14 01-10-2012 10:06 PM
Goodman central air and heat blowing fuses DannyR HVAC 13 05-29-2011 07:21 PM
First time with old style fuses in fuse panel darsunt Electrical 3 06-20-2007 04:53 PM
