A/c Fuses? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-22-2012, 03:23 PM   #1
a/c fuses?
I was replacing a thermostat to my central heating/a/c. while re-wiring the new unit, there was a pop and now there is no power. The Honeywell guy told me that I probably blew a fuse. However, I can't find any fuses anywhere. Can somebody please help me with this? We don't have the funds to hire a professional for something that sounds so small. It's over 100 degrees today and I have kids in the home. Thanks a bunch!
twenta is offline   Reply With Quote
Old 04-22-2012, 03:26 PM   #2
Electrician
Rewards Points: 802
May have to open up your unit and see if there is a fuse on the circuit board.
darren is offline   Reply With Quote
Old 04-22-2012, 03:47 PM   #3
Code05's Avatar
Rewards Points: 1,104
Many times you will find it in the inside interior air handler. It is usually a 2 or 3 amp car fuse. Sometimes there is already a spare in there.
Turn off breaker(s) before removing panels.
Code05 is offline   Reply With Quote
Old 04-22-2012, 03:51 PM   #4
I=E/R
a7ecorsair's Avatar
To add a little to what Darren posted..
Your thermostat needs 24 volts AC, but depending on the furnace design, the 24 volts could be from the control board in the furnace or you may have a small transformer mounted somewhere that is providing the 24 volts using house power.
a7ecorsair is offline   Reply With Quote
Old 04-22-2012, 04:23 PM   #5
i appreciate the answers. However, I have taken off the panel to the a/c unit, and there is a main board (like in a computer) but no fuses, and no indication that anything was wrong. Also, there is a box on the house by the a/c unit that I opened and it actually speaks of fuses on one part, but then the panel below says there are no fuses contained. Because of the popping and the way the whole thing happened, a fuse sounds like the most logical answer, but the problem is that I still can't find any fuses. Also, I have read that there may be a restart button on the unit as well, but could not find one of those either. Any more suggestions?
Old 04-22-2012, 04:31 PM   #6
Rewards Points: 1,766
Where did you hear the pop? Near the thermostat or from outside?
Look on the furnace panels/backside of a door for a wiring diagram and look for a fuse. Usually indicated by a ~ kind of symbol.
bob22 is offline   Reply With Quote
Old 04-22-2012, 04:32 PM   #7
Code05's Avatar
What is the brand name of the unit?
Old 04-22-2012, 04:34 PM   #8
You sure it wasn't the circuit breaker? A lot of times it is hard to tell they are tripped. They must be switched to off position and then back to on.
There should be a fuse on that circuit board, but they don't make noise when blown.
Try the breaker.
jammin06 is offline   Reply With Quote
Old 04-22-2012, 04:35 PM   #9
Electrician
Rewards Points: 802
Did you check the breaker. If the breaker is still on maybe turn it off and turn it back on and see if it resets itself.
Old 04-22-2012, 05:20 PM   #10
Thanks, but yes I've tried the breaker. And, no it doesn't need to be replaced, because I switched the one from the upstairs unit and still the same results! I'm at a loss. there is like a "motherboard" under the panel on the a/c unit, but nothing that looks wrong or blown.
Old 04-22-2012, 05:35 PM   #11
I'm Your Huckleberry
Rewards Points: 2,270
Post a picture or two. Make and model number of the furnace would be nice as well.
You need to check for 24 volts across the R and the C terminal on the control board.
With the furnace door off and the door switch held in, is there an led light on the control board that is lit up? If not then the board is not receiving power. This is going to be a fuse or the transformer.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 04-22-2012, 05:35 PM   #12
The unit is a Puron by Carrier. The popping and spark came from the wires coming from the wall intended for the thermostat. I was connecting the wires to the thermostat at the time. Model 38EYG048300.
Old 04-22-2012, 05:36 PM   #13
They certainly do.
Thanks.
Old 04-22-2012, 05:39 PM   #14
No, the unit is not a Puron by carrier. Puron is the type of refrigerant, hfc 410-A to be exact, first used by Carrier and that correlates to the condensing unit, not the furnace.
Model numbers would help.
Yes, you needed to turn the breaker OFF to the FURNACE prior to any stat work. You blew the fuse or the transformer as it was live.
Thanks.
Old 04-22-2012, 06:05 PM   #15
Rewards Points: 150
Being a Carrier unit I believe Code 5 is right on. Look for an automotive 3amp or so plug in type fuse on the control board that will be located in the air handler inside of the house.. They do not "pop" and make a noise so much.
Jeeps is offline   Reply With Quote
Heat pump wiring and fuses icandoitmyself1 HVAC 13 06-01-2014 04:15 AM
Are fuses still used in new construction? SilveradoGuy Electrical 6 01-17-2012 05:23 PM
Replacing 240V fuses for dryer Mark77 Electrical 14 01-10-2012 09:06 PM
Goodman central air and heat blowing fuses DannyR HVAC 13 05-29-2011 06:21 PM
First time with old style fuses in fuse panel darsunt Electrical 3 06-20-2007 03:53 PM
