A/C Disconnect Box Specs From Wall - Electrical - DIY Chatroom Home Improvement Forum
Old 07-11-2012, 06:52 PM   #1
A/C disconnect box specs from wall
I was wondering if there is any NEC code specs for how close the disconnect can be wall mounted from a corner exterior wall.
I have about 6 inches of space from the left side where another corner wall meets.
jumajunkie is offline   Reply With Quote
Old 07-11-2012, 07:43 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
just make sure nothing is in front of the disconnect...
The Following User Says Thank You to stickboy1375 For This Useful Post:
plummen (07-14-2012)
Old 07-11-2012, 10:00 PM   #3
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I'm curious why you think it could possibly matter?
Old 07-11-2012, 11:39 PM   #4
inspector said it was too close to the wall
Old 07-12-2012, 03:16 AM   #5
Yes, there is - in fact - a stipulation, by the the code, that limits the distance that [a panel] can be installed from the edge of a corner of a wall.
If the meter of the "meter/main" panel is on the right hand side of the equipment, then the distance from the edge of the corner of the wall, to the nearest leading edge of the panel is 18 inches... If the meter of the "meter/main, is on the left hand side of the equipment, then the distance from the coner of the wall, to the center of the meter, is 24 inches.
(It's a PG&E stipulation, but City Inspectors can...and do evoke their arbitrary powers of veto here. The issue arises "if" during emergency exit, personnel "cut" the corner, and run into the meter or panel, causing injury.
kontoose is offline   Reply With Quote
Old 07-12-2012, 04:32 AM   #6
Licensed electrician
Rewards Points: 1,598
Again you have posted a local amendment not even from the NEC. The OP asked about any NEC restrictions.
The Following 4 Users Say Thank You to Jim Port For This Useful Post:
gregzoll (07-12-2012), jbfan (07-12-2012), plummen (07-14-2012), Speedy Petey (07-12-2012)
Old 07-12-2012, 05:01 AM   #7
E2 Electrician
Personally, you could have him site you the violation instead of him telling you it's too close.
Old 07-12-2012, 05:54 AM   #8
k_buz's Avatar
You can say whatever you want, but I don't believe a word of it. Besides, your explanation makes no sense. You are already outside so there is no emergency exit and correct me if I'm wrong but you could cut the corner and run directly into the wall too.
The Following 2 Users Say Thank You to k_buz For This Useful Post:
Old 07-12-2012, 05:56 AM   #9
E2 Electrician
And if the meter wasn't there they would run into a wall? , unless of course they don't want the meter to sustain injury.
Old 07-12-2012, 06:00 AM   #10
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
Don't tell me. It's a home inspector.
I love it, but I cringe, when folks say "The inspector said ..."
9-1/2 times out of ten they are referring to a H-I, which holds ABSOLUTELY no authoritative powers. NONE.
And 5 times out of ten they are wrong.
Old 07-14-2012, 10:07 PM   #11
Master Electrician
Hey I resemble that remark :D
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 07-14-2012, 10:20 PM   #12
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
What in the world are you talking about?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
The Following User Says Thank You to plummen For This Useful Post:
Speedy Petey (07-14-2012)
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 4 04-04-2017 07:38 PM
Core filling a bowing wall, please assist silverstrike Building & Construction 12 06-16-2012 10:28 PM
Retaining wall problem FMS Landscaping & Lawn Care 6 07-04-2011 06:42 PM
creating door in possible load bearing wall acerunner Building & Construction 6 07-05-2010 04:33 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
