-   -   A/C disconnect box specs from wall (http://www.diychatroom.com/f18/c-disconnect-box-specs-wall-149977/)
jumajunkie 07-11-2012 06:52 PM
I was wondering if there is any NEC code specs for how close the disconnect can be wall mounted from a corner exterior wall.
I have about 6 inches of space from the left side where another corner wall meets.
stickboy1375 07-11-2012 07:43 PM
12 Attachment(s)
just make sure nothing is in front of the disconnect...
k_buz 07-11-2012 10:00 PM
I'm curious why you think it could possibly matter?
jumajunkie 07-11-2012 11:39 PM
inspector said it was too close to the wall
kontoose 07-12-2012 03:16 AM
Yes, there is - in fact - a stipulation, by the the code, that limits the distance that [a panel] can be installed from the edge of a corner of a wall.
If the meter of the "meter/main" panel is on the right hand side of the equipment, then the distance from the edge of the corner of the wall, to the nearest leading edge of the panel is 18 inches... If the meter of the "meter/main, is on the left hand side of the equipment, then the distance from the coner of the wall, to the center of the meter, is 24 inches.
(It's a PG&E stipulation, but City Inspectors can...and do evoke their arbitrary powers of veto here. The issue arises "if" during emergency exit, personnel "cut" the corner, and run into the meter or panel, causing injury.
Jim Port 07-12-2012 04:32 AM
Again you have posted a local amendment not even from the NEC. The OP asked about any NEC restrictions.
stickboy1375 07-12-2012 05:01 AM
12 Attachment(s)
Personally, you could have him site you the violation instead of him telling you it's too close. :)
k_buz 07-12-2012 05:54 AM
You can say whatever you want, but I don't believe a word of it. Besides, your explanation makes no sense. You are already outside so there is no emergency exit and correct me if I'm wrong but you could cut the corner and run directly into the wall too.
stickboy1375 07-12-2012 05:56 AM
12 Attachment(s)
And if the meter wasn't there they would run into a wall? :no: , unless of course they don't want the meter to sustain injury. :)
Speedy Petey 07-12-2012 06:00 AM
Don't tell me. It's a home inspector. :whistling2:
I love it, but I cringe, when folks say "The inspector said ..."
9-1/2 times out of ten they are referring to a H-I, which holds ABSOLUTELY no authoritative powers. NONE.
And 5 times out of ten they are wrong.
andrew79 07-14-2012 10:07 PM
Hey I resemble that remark :D
plummen 07-14-2012 10:20 PM
1 Attachment(s)
What in the world are you talking about?
