Old 06-07-2011, 07:11 AM   #1
A/C circuit breaker
Why does our A/C circuit breaker occasionally trip
able33 is offline   Reply With Quote
Old 06-07-2011, 07:25 AM   #2
A/C circuit breaker
Circuit overlaod due to an about to fail component, or possibly a bad breaker.
Old 06-07-2011, 07:26 AM   #3
Electrician
SD515's Avatar
A/C circuit breaker
Usually overload or overcurrent, or is getting worn out and can no longer handle the ampacity its rated for. If you give a better description of your problem, we might be able to give you a better answer.
Kyle
Old 06-07-2011, 02:11 PM   #4
Lic Electrical Inspector
electures's Avatar
A/C circuit breaker
Nameplate info?
Breaker info?
Disconnect info?
Wire size?
electures is offline   Reply With Quote
circuit breaker? blueandyellow Electrical 7 01-30-2011 11:27 PM
Need to ID old circuit breaker box oldfeller Electrical 11 07-26-2010 05:00 PM
A/C unit keeps throwing circuit breaker MofElPaso HVAC 15 05-03-2010 12:06 PM
Circuit BReaker Question - breaker didn't trip and no power thru the circuit Ronin_67 Electrical 2 08-08-2008 07:06 AM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 06:55 AM
