Bypassing The Compassator On A 5.5 Electric Motor - Electrical - DIY Chatroom Home Improvement Forum
Old 11-12-2011, 06:24 PM   #1
bypassing the compassator on a 5.5 electric motor
how do you bypass the compassitor on a 5.5 motor on a craftsman aircompreesor
Rickey Lowery is offline   Reply With Quote
Old 11-12-2011, 06:30 PM   #2
Rewards Points: 1,578
on the left.
I imagine the capacitor is to start the motor and without it, the motor will not start.
Why do you want to bypass it?
A motor person may have another perspective to offer.
bob22 is offline   Reply With Quote
Old 11-12-2011, 08:31 PM   #3
Idiot Emeritus
Rewards Points: 1,492
You could simply connect the two leads together, but it will not start without a capacitor.
If it has two capacitors, it won't start without the start capacitor, and it might start without the run one, and if it does, it'll run at reduced HP and higher amperage.
In short, the motor needs its capacitor(s) in order to run properly.
Rob
micromind is offline   Reply With Quote
Carrier Hi 90 Furnance variable speed motor ahenderson HVAC 0 12-18-2010 07:28 AM
New fan motor going out? DavidI HVAC 5 06-23-2010 10:38 AM
Motor control wiring problem dgr68 Electrical 8 01-04-2009 05:13 PM
Wiring from electric motor subman Electrical 1 06-24-2005 10:37 PM
Wiring from electric motor Submarineman Electrical 1 06-17-2005 12:50 AM
