Bypass A Light Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 03-24-2009, 05:02 PM   #1
Bypass a light switch
Converted a third bedroom to a walk-in closet; Wall units will cover up light switch so I want to take the switch out and put a blank plate over it. I have a WHT and BLK from source to switch and a BLK WHT RED coming from plug. On the plug I have RED and 2 WHT's with BLKs wire together. To bypass the switch… do I wire BLKs together and WHT's together, what do I do with the red? On the plug…do I need to do anything? The switch worked the top plug.
skyhigh82 is offline   Reply With Quote
Old 03-24-2009, 05:12 PM   #2
Remodeling Contractor
Connect the red with the other blacks which will make both outlets hot all the time. But you cannot be burying this box.
Old 03-24-2009, 05:42 PM   #3
You can still access the box by removing a shelf from the shoe rack.
Old 03-24-2009, 06:18 PM   #4
ok...i have 62.6 volts on the wht and 2.6 volts on the blk with the plug indicating open ground.
Old 03-24-2009, 06:19 PM   #5
The whites in the switch box splice are not connected correctly
Old 03-25-2009, 05:33 PM   #6
Turned off the breaker and went through all outlets and found a broken ground wire in the forth one I checked. Everything is grounded and I have 110/120v at each outlet.
Old 03-25-2009, 06:30 PM   #7
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Originally Posted by skyhigh82 View Post
.......I checked. Everything is grounded and I have 110/120v at each outlet.
Congratulations on your due diligence
Disclaimer
& Stay Safe
.....Bob Lavery
Wiring from light to switch and on poorjohn Electrical 3 03-16-2009 01:23 PM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
Light Switch to Detached Garage - Grounding Issue smitty286 Electrical 1 10-22-2008 12:17 PM
Adding second light switch to an existing light TexasEd Electrical 7 08-15-2008 06:22 PM
Problem changing light switch grgryl Electrical 14 08-10-2008 01:26 PM
