Bypass Light Option On Remote Control - Electrical - DIY Chatroom Home Improvement Forum
Old 11-18-2012, 01:53 AM   #1
Rewards Points: 123
bypass light option on remote control
Hi:
I just installed a remote dimmer and fan control in my ceiling fan. I'm not happy with the dimmer switch it won't stay in a dim setting and with one touch boosts up too high. I really don't want the dimmer switch anyway and installed it really for the fan control. I want static very low wattage, dim bulbs without the dimmer option: Question: Can I just bypass the remote control on the lights but keep the fan remote function, maybe by disconnecting the blue wire from the transmitter, capping it unconnected, and then connect blue wire from the fan/light unit to the incoming hot wire that is also connected to the red wire on the other side of the transmitter. Or would I have to maybe piggy back the hot wire, one to the transmitter and one to the blue wire from the fan/light unit? Hope this doesn't sound crazy scary, I'm probably not thinking this all the way through.
DiegoJames is online now   Reply With Quote
Old 11-18-2012, 07:12 AM   #2
Electrical Contractor
kbsparky's Avatar
You can bypass that remote receiver and connect your lights directly to the original wire in the ceiling box. Should not be a problem.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
DiegoJames (11-18-2012)
Hunter Ceiling Fan & Light control #27182 slrholmes Electrical 23 03-28-2014 06:46 AM
Remote Control Toggle Switch for Sconce patdmania Electrical 0 04-06-2011 07:31 PM
Remote Control Ceiling Fan - switch required? bvbellomo Electrical 7 11-10-2010 09:07 AM
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 03:44 PM
Additional Wall Switch to control light tiame Electrical 6 07-04-2009 12:54 AM
