BX Wiring Plug Change - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-31-2014, 10:49 AM   #16
Licensed electrician
Rewards Points: 1,242
The short answer is no.
Can you just extend from the other room for a new receptacle?
Old 01-31-2014, 10:55 AM   #17
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
^^ +1 ^^
That would be my suggestion. If you can run a single wire for ground, you can run a new cable and install a new grounded receptacle.
Coastal South Carolina
Old 01-31-2014, 11:38 AM   #18
Rewards Points: 808
Neither my cable box, flat screen TV, nor my Bose stereo have grounds on them. Why do yours? The reality is very few appliances and tools these days have that 3rd ground pin on them as most of these things are now built "double insulated" and don't have any use for a ground. Plugging a TV or a stereo with no ground pin on it's male connector into a grounded outlet does nothing for the device anyway. If you simply want new receptacles, they sell new 2-prong replacements for what you have. If you can run a ground wire to an already existing grounded circuit, it would be better to simply run a new romex (NM cable) there instead and be done with it.
IslandGuy is offline   Reply With Quote
Old 01-31-2014, 11:41 AM   #19
A "Handy Husband"
rjniles's Avatar
People very often want to use surge protectors with expensive electronics. A surge protector only works when plugged into a grounded receptacle.
A whole house surge protector at the breaker panel is a better option.
The Following User Says Thank You to rjniles For This Useful Post:
gregzoll (02-04-2014)
Old 01-31-2014, 11:42 AM   #20
Rewards Points: 93
Thanks guys, the home inspector said "this room is not grounded which is a potential hazard as the way it's configured the BX could become live"!!
Are you suggesting just add new outlets in the old room off of the new rooms circuit?
johnpma is offline   Reply With Quote
Old 01-31-2014, 11:49 AM   #21
A "Handy Husband"
rjniles's Avatar
The HI is just playing "CYA".
Yes, we are saying extend the other room's grounded circuit to a new receptacle(s) in this room.
Old 01-31-2014, 11:59 AM   #22
Rewards Points: 93
Thanks rj
From what I've read I can have up to 6 receptacles on a 15 amp circuit??
Old 01-31-2014, 12:08 PM   #23
A "Handy Husband"
rjniles's Avatar
Thanks rj
You can have as many as you want. There is no limit in the NEC
Old 02-04-2014, 09:30 AM   #24
Rewards Points: 93
What would you do with the old wiring/receptacles that I can't replace with new ones (exterior walls)? Leave it and disconnect the breaker?
Old 02-04-2014, 10:06 AM   #25
Rewards Points: 6,652
Just Canada as far as we know. Then again, there could be a AHJ out there, wanting their area to be the same way. What I am meaning, is a limit in the number of devices wired on the circuit.
Critique my Panel Wiring Please Ocelaris Electrical 14 03-16-2013 02:10 PM
Custom wiring a generator to a transfer switch robojoe_fl Electrical 4 06-08-2011 01:36 AM
help wiring up computer fan with wall outlet plug marstang50 Electrical 9 12-29-2009 06:07 AM
220 Welder Plug Wiring ryankalel Electrical 14 10-07-2008 09:21 PM
wiring a usa plug Unregistered Electrical 5 02-28-2004 12:57 PM
