BX Wiring Plug Change - Electrical - DIY Chatroom Home Improvement Forum
Old 12-18-2013, 07:58 AM   #1
Rewards Points: 93
purchased an older home with BX wiring. I want to change the outlets over to 3 prong outlets. The inspector told me that I can't simply ground to the metal box as the ground in certain situations can become "hot"........Does this mean that I have to install GFCI outlets in all these locations? I have about 6 outlets that need changing
johnpma is offline   Reply With Quote
Old 12-18-2013, 08:18 AM   #2
Licensed electrician
Rewards Points: 1,788
First you need to check to see if your wiring has a thin bond strip in it. This will determine the next step.
Look at an end of the cable near a box or the panel.
Old 12-18-2013, 10:32 AM   #3
Rewards Points: 93
Excuse my stupidity but what is a thin bond strip
Old 12-18-2013, 11:19 AM   #4
If your cable has this you can install grounded receptacles.
It is a thin conductor added under the sheath and looks silver.
Old 12-18-2013, 11:22 AM   #5
Rewards Points: 93
ahhhh gotcha I'll check it out. Thank you
Old 12-18-2013, 01:33 PM   #6
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,228
http://www.nema.org/Technical/Docume...d_12_15_11.pdf
Coastal South Carolina
Old 12-20-2013, 10:51 AM   #7
Rewards Points: 93
no wire like shown
Old 12-20-2013, 11:16 AM   #8
The only way to use 3 prong receptacles with your ungrounded wiring would be to install GFI protection. The receptacles would not be grounded.
You could also run a ground from the panel to each receptacle.
Old 12-20-2013, 11:25 AM   #9
Rewards Points: 93
What does this mean?? Good bad? Safe?
Old 12-20-2013, 01:09 PM   #10
A "Handy Husband"
rjniles's Avatar
Why do you want to upgrade from 2 to 3 wire receptacles? If you are only plugging in things with 2 wire cords like lamps, the ground wire does nothing.
Old 12-20-2013, 01:15 PM   #11
Rewards Points: 93
Computers, TV, Cable box ect....
Old 12-20-2013, 01:22 PM   #12
A "Handy Husband"
rjniles's Avatar
Valid reason. Run a new circuit from those locations back to the breaker panel.
You could run a single conductor back to the panel for ground but that is as much work as running a new cable.
And don't ask if you can run a a single ground to a metallic water pipe. NO
Old 12-20-2013, 01:23 PM   #13
It can be just as easy to run new grounded circuits where needed. You also do not need to worry about the loads on the old circuits.
rjniles (12-20-2013)
Old 12-20-2013, 04:51 PM   #14
Rewards Points: 6,652
!most times you will not see it, due to they would take it back out where the BX enters the clamp, and wrap the excess of it around the screw a couple of turns.
Go look in the attic and see if the strip exits the clamp, if you do not see it inside the fixture box.
Old 01-31-2014, 07:38 AM   #15
Rewards Points: 93
Well it's gonna take an act of God to run a new circuit to this room.
But I have a question The next room over was remodeled back in the 70's and rewired at the tome with romex......my question it can I run a ground wire from a receptacle in the newly remodeled room to the room that still has the BX to achieve an adequate ground??
Critique my Panel Wiring Please Ocelaris Electrical 14 03-16-2013 01:10 PM
Custom wiring a generator to a transfer switch robojoe_fl Electrical 4 06-08-2011 12:36 AM
help wiring up computer fan with wall outlet plug marstang50 Electrical 9 12-29-2009 05:07 AM
220 Welder Plug Wiring ryankalel Electrical 14 10-07-2008 08:21 PM
wiring a usa plug Unregistered Electrical 5 02-28-2004 11:57 AM
