BX Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 01-31-2012, 05:47 PM   #1
DIY
Rewards Points: 39
Question
BX Wiring
I've read that it is not ideal to coil electrical wiring due to the possibility of heat. Is this true in all cases and all types of wiring? I have some BX wiring that is too long since I moved some stuff around and am trying to figure out if I should just coil it a few times, or, cut it down to size.
Can you guys let me know if coiling wire is bad with BX? I'm guessing that I should cut it down to size, but wanted to hear from the more experienced.
RocketManZ is offline   Reply With Quote
Old 02-01-2012, 02:04 AM   #2
DIY
Rewards Points: 39
Question
Anyone?
Old 02-01-2012, 02:11 AM   #3
Julius793's Avatar
I have zero clue what you mean by coiling, can you please explain you question.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 02-01-2012, 03:50 AM   #4
Semi-Pro Electro-Geek
Rewards Points: 2,902
If you have less than 4 tightly spaced wraps, it should definitely be fine (based on the NEC's 7-conductor limit for thermal derating). More than that could pose some risk of excessive heat. Really you would have to have a fairly large coil of wire under heavy load before it would get noticeably hot.
But BX? As in actual BX with no separate grounding conductor, not MC or new AC cable which look sort of like the old BX? That hasn't been used for decades - and shouldn't be.
mpoulton is offline   Reply With Quote
Old 02-01-2012, 04:27 AM   #5
Rewards Points: 1,192
The longer the cable,the greater the voltage drop due to resistance.Also, the job would look cleaner without excess cable.
bobelectric is offline   Reply With Quote
Old 02-01-2012, 12:01 PM   #6
DIY
Rewards Points: 39
Coils, Wraps, that is what I meant. Sounds like a few wraps are ok then based on what you mentioned in the NEC.
Not sure if it is actual BX or not, it says 10TW 600V on it. It comes from an addition that was done in the 1960-1970's and the rest of the house has typical old school BX with the ground running through the box and wire sheathing. I have to look again, but I don't think there was an actual ground wire, just 2-10 gauge wires.
I needed to extend the location of the thermostat so I pulled the original BX style wire to the basement, put a metal junction box, and then used 10 NM-B to go from the junction to the thermostat. Sound ideal?
Old 02-01-2012, 07:09 PM   #7
I assume this is for electric baseboard heat, right? That should be OK. If it doesn't have a separate grounding conductor or at least a continuous bonding strip (a small bare metal strip inside the cable) then it must be considered ungrounded and should not be extended or re-used.
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 10:01 AM
Backyard wiring questions MikeInDetroit Electrical 1 11-02-2011 10:46 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 07:45 PM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 09:53 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
